PapaLazarou Posted July 15, 2005 Share Posted July 15, 2005 Hello all, I'm running a 2002 megablade on 15 inch wheels with Yoko A539s. What tyre pressures do you reckon I should be running on road and track? Thanks in advance for your help. Patrick. Quote Link to comment Share on other sites More sharing options...
adhawkins Posted July 15, 2005 Share Posted July 15, 2005 Start at 18psi. Go for a blast down a straightish road. Check the temperature on the inside, centre and outside of each tyre. If the edges are hotter, you need more pressure. If the centre is hotter, you need less. Andy Quote Link to comment Share on other sites More sharing options...
