Glen H Posted June 26, 2005 Share Posted June 26, 2005 Westfield stainless exhaust system for sale, 12 months old, done just under 2000 miles, c/w integral catalytic converter, all parts in excellent condition and even been given a quick polish. 5 1/2 inch stainless silencer c/w integral catalytic converter and mounting boss for Lamda sensor, excellent condition - £200 (plus P+P) Stainless manifold 4-2-1 branches, excellent condition, already covered in exhaust wrap (black coloured type, it not dirty ) this is only covered where it sits within the engine bay and stops where the manifold exits the body tub, however it can be removed very easily if preferred. - £175 (Plus P+P) Westfield, heat sheild to suit above silencer, very good condition. - £20 (plus P+P) Link to comment Share on other sites More sharing options...
pistonbroke2 Posted June 26, 2005 Share Posted June 26, 2005 What you up to Proff.? Link to comment Share on other sites More sharing options...
Paul Hurdsfield - Joint Manchester AO Posted June 27, 2005 Share Posted June 27, 2005 Westfield stainless exhaust system for sale, 12 months old, done just under 2000 miles, c/w integral catalytic converter, all parts in excellent condition and even been given a quick polish. 5 1/2 inch stainless silencer c/w integral catalytic converter and mounting boss for Lamda sensor, excellent condition - £200 (plus P+P) Stainless manifold 4-2-1 branches, excellent condition, already covered in exhaust wrap (black coloured type, it not dirty ) this is only covered where it sits within the engine bay and stops where the manifold exits the body tub, however it can be removed very easily if preferred. - £175 (Plus P+P) Westfield, heat sheild to suit above silencer, very good condition. - £20 (plus P+P) Not quite the right weather for taking the car off the road with upgradeitus Glen Link to comment Share on other sites More sharing options...
SteveF Posted June 27, 2005 Share Posted June 27, 2005 Glen - may be interested - can you give me a bit more info, is it repackable? what sort of noise level did it acheive? - or can it be 'made' to pass SVA - and re-adjusted for better flow afterwards? Steve Link to comment Share on other sites More sharing options...
Glen H Posted June 27, 2005 Author Share Posted June 27, 2005 Not quite the right weather for taking the car off the road with upgradeitus Glen Its not off the road for upgradeitus, its off the road due to bent wishbone (well, suppose I will be upgrading when I can get hold of some affordable Widetrack wishbones) The exhaust was changed a while back, only just got round to sorting the posting out though Link to comment Share on other sites More sharing options...
Glen H Posted June 27, 2005 Author Share Posted June 27, 2005 Glen - may be interested - can you give me a bit more info, is it repackable? what sort of noise level did it acheive? - or can it be 'made' to pass SVA - and re-adjusted for better flow afterwards? Steve No its not repackable, its the standard Westfield silencer, with the integral Cat concerter (req'd for SVA), not sure if any with the integral CAT. are repackable Noise level was close at SVA, passed at 100.3Db, just had to play / alter the angle of the tail pipe on the day (and make sure the bonnet is on) If your worried about noise, When I helped Craig-C put his Busa through SVA the other week, we did put a couple of stainless steel pan scourers in the silencer (manifold end) and this brought hte noise down by 2Db (was initially 103Db again with CAt Converter), then removed them afterwards Glen Link to comment Share on other sites More sharing options...
Paul Hurdsfield - Joint Manchester AO Posted June 28, 2005 Share Posted June 28, 2005 If your worried about noise, When I helped Craig-C put his Busa through SVA the other week, we did put a couple of stainless steel pan scourers in the silencer (manifold end) and this brought hte noise down by 2Db (was initially 103Db again with CAt Converter), then removed them afterwards Glen Wadya mean 'I' Surely you mean we Ive still got the bruises and burn marks to prove it Link to comment Share on other sites More sharing options...
