nikpro Posted June 1, 2005 Posted June 1, 2005 I am due to collect my Kit 2 weeks today and up untill now was under the impression it was fitted with a standard Diff, however someone else has said the 18oo Speed Sport on throttle bodies has a limited slip diff; is this correct? Quote
Mark Stanton Posted June 1, 2005 Posted June 1, 2005 depends what box you ticked on the options list best check with factory Quote
steppenwolf Posted June 1, 2005 Posted June 1, 2005 When I bought my SpeedSport kit in 1999 the LSD was the standard unit supplied for a period of the time but I think it is now an option. Quote
neilwillis Posted June 1, 2005 Posted June 1, 2005 You'll find that option will be slightly more costly, and if you wanted to specify a slippy diff, just ring them, and they'll certainly let you make the change. Quote
Mike H Posted June 1, 2005 Posted June 1, 2005 It was an option when I built my first car in 2000. At the time the LSD was 4.09:1 ratio and about another £400 or so. Best to ring them and find out. Mike Quote
Mark B Posted June 2, 2005 Posted June 2, 2005 A genuine speedsport does have an lsd fitted as standard, along with throttle body fuel injection, trakspax suspension, 7 x 15 wheels with 205/50/15 tyres and front & rear anti roll bars. HTH, Mark. Quote
