Steve R Posted April 25, 2005 Share Posted April 25, 2005 I'm just about to order a set of rear discs for my Megablade (SEiW). Does it make any difference that I plan to use the Golf rear callipers? From doing a search I believe that the usual parts to fit on the rear are Escort Mk3 front discs. Do I need a different offset / diameter / thickness disc with the Golf callipers? By the way, I'm also using a Freelander diff and driveshaft assemblies if that makes a difference at all. Thanks in advance, Steve. Quote Link to comment Share on other sites More sharing options...
Blatman Posted April 25, 2005 Share Posted April 25, 2005 Nope. Use the Mk 3 Escort *front* discs... Quote Link to comment Share on other sites More sharing options...
Barry Ashcroft Posted April 25, 2005 Share Posted April 25, 2005 I am lead to believe that the rear uprights are different if using the golf calipers????? Barry Quote Link to comment Share on other sites More sharing options...
Glen H Posted April 25, 2005 Share Posted April 25, 2005 I am lead to believe that the rear uprights are different if using the golf calipers????? Barry Me too, you need to check this out first Quote Link to comment Share on other sites More sharing options...
Arm Posted April 25, 2005 Share Posted April 25, 2005 Not on mine. The Sierra calipers came off and the Golf ones bolted on. Quote Link to comment Share on other sites More sharing options...
Steve R Posted April 26, 2005 Author Share Posted April 26, 2005 Thanks chaps, Have now ordered some Mk3 Escort front discs from Rally Design so will see if they fit... should be ok by the sounds of things. Cheers, Steve. Quote Link to comment Share on other sites More sharing options...
