nigelh Posted April 20, 2005 Share Posted April 20, 2005 Any newbies out there about to fit a floor mounted accel. pedal? If so could you do me a big favour and measure the small brass insert that holds the cable please? Diameter and length would be great. I would measure my own but I am a long way from home (middle of the Irish Sea). I do however have access to a lathe and plan to make a modified version to accept twin cables. The idea of doing this on company time with their materials and machines has given me a warm glow of satisfaction!!! Quote Link to comment Share on other sites More sharing options...
geofff Posted April 23, 2005 Share Posted April 23, 2005 Hi nigelh, I've measured up the hole in my spare accelerator pedal (which the brass insert ifts into) and the dimensions are: 9.82mm diameter hole - probably should be 10mm but for the powder coating gap inbetween the two prongs of the pedal is 7.0mm total width of the pedal at the two prongs of the pedal is 13mm Hope that helps Geoff Quote Link to comment Share on other sites More sharing options...
nigelh Posted April 25, 2005 Author Share Posted April 25, 2005 Top Job!! Thanks very much Geoff, just what I needed to know and in the nick of time. If we ever meet.......I owe you a pint cheers Nige. Quote Link to comment Share on other sites More sharing options...
geofff Posted April 25, 2005 Share Posted April 25, 2005 My pleasure. Ta Geoff Quote Link to comment Share on other sites More sharing options...
