Guest Posted April 15, 2005 Share Posted April 15, 2005 Could anyone tell me the size of the front splined wheel studs on my 1800 speedsport. I assume that they are a Ford fitting. I need to order some longer ones as thay barely come to the end of the nuts and, from the advice on here, I would feel safer with a bit more thread. Thanks, John Quote Link to comment Share on other sites More sharing options...
Graham Posted April 15, 2005 Share Posted April 15, 2005 They are an M12x1.5 thread. I think they are 41mm long, either way they are 'standard length'. You can get +13mm or +25mm from places like Rally Design. Sounds like you want +13mm. Like these... Extended studs Quote Link to comment Share on other sites More sharing options...
Mark B Posted April 15, 2005 Share Posted April 15, 2005 John, They are a ford fitting, westfield can supply 2 or 3 different lengths, otherwise as Graham mentions, rally design or demon thieves do different length studs. Cheers, Mark. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 15, 2005 Share Posted April 15, 2005 Thank you both. I will call these suppliers. Regards, John Quote Link to comment Share on other sites More sharing options...
