Crossflow Engine For Sale
Crossflow engine for sale. Completed 1000mls since build. Built by Jaguar Engine Development Engineer. Details as follows (pretty similar spec to Vulcan engine sold a few weeks ago...):-
711M 1600cc block
10.6:1 compression ratio
AE Hepolite pistons +0.090”. Valve posckets cut to suit cam lift/duration.
Kent 244 Camshaft
Vernier Duplex timing gear
Ported & Polished Head fitted with new valve guides, 41.3mm Stainless Inlet and 33.7mm Stainles Exhaust valves
Steel rocker posts and heavy duty rocker shaft.
Vandervell bearings
Box Baffled Trapdoor Shallow Sump (gives groundline level with bottom of bellhousing)
High pressure oil pump
Alloy front crank pulley
Lightweight Flywheel, balanced bottom end incl balanced and polished Conrods & balanced pistons.
Modified block breather
Twin 40 Dellorto carbs and alloy inlet manifold to suit.
Pipercross air filter with allo backplate.
Alloy inlet trumpets.
Alloy carb linkage.
Lumenition Electronic Ignition System
Clutch and cover to suit Type 9 gearbox
4-2-1 exhaust manifold to suit 7-type car
When dyno'd gave 135bhp at the flywheel - copy of power curve available if required.
Other bits included if you want them:-
Engine mount brackets.
Thermostat housing with filler cap (pretty rare I think)
Set of 4 90thou 1300cc pistons and rings (used to give high CR in 1600c engine)
Set of conrods (if i can find them)
Rocker shaft and rockers
Other bit's and bobs of xflows as i find them.
Offers around £800
Engine Located in Kenilworth, Warwickshire.
Ray Grilli
07712-439588
01926-511324
  • 2 weeks later...
