mikey d Posted March 28, 2005 Share Posted March 28, 2005 decided to change a radiator hose this weekend and after refilling the cooling system, i am now having overheating problems, i am assuming it must be an air lock but just can't seem to shift it. My car is a SE with toyota 4AGE. I'm very p***ed off 'cus i haven't had a decent blat over this easter weekend, can anyone offer any advice? Thanks MIKE Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted March 28, 2005 Share Posted March 28, 2005 Squash your pipes and push some water around Quote Link to comment Share on other sites More sharing options...
Major Stare Posted March 28, 2005 Share Posted March 28, 2005 Raise the header tank as high as possible, remove if you can and pump the pipes. Quote Link to comment Share on other sites More sharing options...
mikey d Posted March 29, 2005 Author Share Posted March 29, 2005 thanks guys tried your comments already but with no joy, i'll have another bash at the weekend Quote Link to comment Share on other sites More sharing options...
Major Stare Posted March 29, 2005 Share Posted March 29, 2005 Do you have a heater ? Quote Link to comment Share on other sites More sharing options...
mikey d Posted March 30, 2005 Author Share Posted March 30, 2005 no heater! Quote Link to comment Share on other sites More sharing options...
R.Lawrence Posted April 1, 2005 Share Posted April 1, 2005 Do you have a thermostat housing. If so this can cause problems. Quote Link to comment Share on other sites More sharing options...
cidersurfer Posted April 1, 2005 Share Posted April 1, 2005 Jack the back/front of the car up as high as you can safely and bleed/squeeze/squash again! Quote Link to comment Share on other sites More sharing options...
RobHaines Posted April 1, 2005 Share Posted April 1, 2005 I'm having the same problem, with a standard xflow. I have a tried squeezing the pipes but it doesn't seem to have got any better. I have a heater, which I only use to bring the engine temp down at the moment would disconnecting it help? Quote Link to comment Share on other sites More sharing options...
pmc_3 Posted April 4, 2005 Share Posted April 4, 2005 If its anything like an mr2 cooling system there are bleed valves that need opening to get rid of the air. Quote Link to comment Share on other sites More sharing options...
Redcar Posted April 7, 2005 Share Posted April 7, 2005 initially i had overheating problems with the xflow, could not get rid of air pockets so i jacked the front up as high as possible, Took off the bottom rad hose (empty system) angled up the hose as high as possible and fed in the water into the engine from the bottom up, out of the top and into the rad (top hose and caps all on) until the water started coming out of the bottom rad hole. Then refitted the bottom hose and ran up the engine (to circulate the water) and then toped up via the expansion tank.to completly fill the system Never had a problem since I think there may have been pockets either side of the ater pump filling it from the top and hence no circulation. Quote Link to comment Share on other sites More sharing options...
mikey d Posted April 7, 2005 Author Share Posted April 7, 2005 thanks for all your suggestions, by raising the front end on ramps and hours of squeezing hoses, running the engine up to temp and venting the hoses by slackening off the jubilee clips and breaking the seal with a screwdriver seems to have done the trick. Quote Link to comment Share on other sites More sharing options...
hilux Posted April 10, 2005 Share Posted April 10, 2005 Ahem, Just a thought but if you have had such issues why not get a coffee when youve got a minute, sit back, study the routing of the pipes and understand the flow. Then try to see if you couldnt install a tee somewhere at the highest point so as to block off for use as a vent next time you need to fill up or top up. The vent need only be a small one. FWIW Quote Link to comment Share on other sites More sharing options...
