Matt Crisp Posted March 24, 2005 Posted March 24, 2005 150 BHP at the wheels is not enough!!! 2litZetec/cams/45's/omex So what next??? Zetec with cams/head mods/posh pistons/valves/omex OR VX with ?? OR Honda/Toyota??? Advice please Matt Quote
adhawkins Posted March 24, 2005 Posted March 24, 2005 Vx should get you easily into the 180BHP plus range. Not sure about Toyota / Honda...haven't heard of any 4-ages generating big power (but that doesn't mean there aren't any). Need to be careful, cos I think some Honda's rotate the wrong way... Andy Quote
stu999 Posted March 25, 2005 Posted March 25, 2005 Matt, the cheapest (and without doubt, the easiest) route is to modify the engine you currently have - or at least, the type of engine you have. A standard VX is only going to give you the same kind of bhp. A conversion to VX will add up (engine mountings, bell housing etc inlet and exhaust manifolds, etc etc) as well as subsequent tuning. Of course, the ultimate potential of the VX is likely to be higher, but at a price. Honda engines could also release a lot more power for you (the likely suspect being a S2000 motor). But there will be a lot of re-engineering involved, and a lot of bespoke stuff made, just to get the engine in the front of your car in the first place. So it is really upto how much money you want to spend, and how much hassle you want. Having a lot of fun with your car as it is, whilst you quietly build up a 'special' motor from another engine, that can be dropped in at your leisure when it is finished has got to be the way forward IMHO. If the worst happens, you have a spare motor to drop back in then too. HTH Stu. Quote
felters Posted March 25, 2005 Posted March 25, 2005 Honda deffo. Plenty of wrecked Fireblades around to steal one from Quote
Mark Purves Posted March 25, 2005 Posted March 25, 2005 Just getting rid of injection and fitting carbs should get you 180 straight away from a Redtop VX lump. I recall something that tells me beware of Honda car engines as the rotate the opposite direction to most other engines. If this is not right I am sure someone will be along shortly. Quote
gadrego Posted March 25, 2005 Posted March 25, 2005 Honda car engines as the rotate the opposite direction Not all do. Think the CTR and S2000 engines are ok. But best of luck to you if you decide to try to install one! Most obvious option by far seems to be to stick with the Zetec. How about some Throttle Bodies and some head work. 180-190 Bhp shouldn't be too difficult to achieve. Talk to Raceline maybe? What am I saying? Get a VX, Zetecs smell! Quote
Martin Keene Posted March 25, 2005 Posted March 25, 2005 It's got to be tune the Zetec. It would cost circa £3k to stick a VX in it and it would be no more powerful, true it would be a better basis for silly power later on, but do you want silly power? £3k on your zetec would be a really nice engine. Quote
Mark Stanton Posted March 25, 2005 Posted March 25, 2005 I would concur with Stu and Martin and for what you could sell your carbs for would release a chunk of money towards throbble botties Quote
stu999 Posted March 25, 2005 Posted March 25, 2005 Just getting rid of injection and fitting carbs should get you 180 straight away from a Redtop VX lump. I know that BHP figures are difficult to compare, but Matt is already getting 150bhp at the wheels from his Zetec. Dropping an otherwise standard VX in is only going to make the same (180 @ flywheel...). Quote
Westfieldman Posted March 25, 2005 Posted March 25, 2005 Don't fit a Duratec It will bankrupt you unless its a new build Quote
conibear Posted March 25, 2005 Posted March 25, 2005 It will bankrupt you unless its a new build Why Paul Quote
Westfieldman Posted March 25, 2005 Posted March 25, 2005 Cos of all the bit you already have don't fit the duratec Flywheel Clutch Bellhousing CRB Exhaust inlet manifold sump or dry sump pan engine mounts plumbing The list goes on but as a new build you need all of the above in one form or another anyway Quote
markcoopers Posted March 25, 2005 Posted March 25, 2005 Matt, if your selling your engine can I have 1st dibs? Well if you don't ask........ Quote
chazpowerslide Posted March 26, 2005 Posted March 26, 2005 Christ Mark, your 1.8 Zetec has only been in a week!!!!!!!!!!! Chaz. Quote
neilwillis Posted March 26, 2005 Posted March 26, 2005 I think someone's been listening to too many people saying this or that engine is better. There's plenty of potential in the Zetec for more power - uprated cams, ported and flowed head, throbble botties etc. Yes, the VX may be more tuneable in the upper end, yes, the Duratec is a far superior engine. Fact is though, you have a Zetec installation, so why not make the thing sing? It's a 16v, lightweight (when compared to a VX) engine, with less potential for catastrophic failures than the VX (check out the water pump issue). It is definitely good for 200 BHP plus without silly money being thrown at it. Or is this a case of the big boys all drive VXs? Quote
