Ted Posted February 27, 2005 Share Posted February 27, 2005 Hi all 1. Just putting my rear arches onto the bodywork and noticed while drilling that the GRP chips sometimes, not a problem with this job but will be on the more visible areas e.g cycle wings. Does anyone have any top tips on how to avoid this?? 2. I have some small scratches on the bodywork, what is the best way to get rid of them??? Thanks in advance TED. Quote Link to comment Share on other sites More sharing options...
perksy Posted February 27, 2005 Share Posted February 27, 2005 1. Use a Drill that Doesn't have Sharp cutting Edges. (Use an Old one or Grind the Cutting edges slightly Blunt) 2. Aslong as their only Slight Surface scratches you can use T-Cut or Brasso (G3 Is another product that is Good, and i think this is available at Screwfix) Hope this Helps Quote Link to comment Share on other sites More sharing options...
steppenwolf Posted February 27, 2005 Share Posted February 27, 2005 Clicky - This may well help with question 1 If the scratches are too deep for the Brasso attack then rub down carefully with 900 grit followed by 1500 grit 'wet and dry' used very wet and with a small amount of washing up liquid added. Finish of with the Brasso. Quote Link to comment Share on other sites More sharing options...
brianm Posted February 27, 2005 Share Posted February 27, 2005 1. Just putting my rear arches onto the bodywork and noticed while drilling that the GRP chips sometimes, not a problem with this job but will be on the more visible areas e.g cycle wings. Does anyone have any top tips on how to avoid this?? Pilot drill, and then csk the hole from the other side to prevent spelching. Bri. Quote Link to comment Share on other sites More sharing options...
Ted Posted February 27, 2005 Author Share Posted February 27, 2005 Thanks all. Hopefully the next set of holes will be neater. The scratches aren't deep so will try the brasso trick. TED Quote Link to comment Share on other sites More sharing options...
predawson Posted February 27, 2005 Share Posted February 27, 2005 Another tip for drilling bodywork. Drill small pilot first, then reverse the drill so that it grinds rather than cuts. Saves blunting the cutting edge by grinding the drill. Goes through in no time and leaves a chip free edge. Quote Link to comment Share on other sites More sharing options...
deano.1 Posted February 27, 2005 Share Posted February 27, 2005 use a drill that you have drilled into some concrete first, it takes the sharpness off the drill and doesn't seem to cause chipping Quote Link to comment Share on other sites More sharing options...
