swiftr Posted February 24, 2005 Share Posted February 24, 2005 Apparently you can roughly line up the beam pattern on the well using a tin top's lights and they will let you adjust them at the test centre. Quote Link to comment Share on other sites More sharing options...
Man On The Clapham Omnibus Posted February 25, 2005 Share Posted February 25, 2005 Nigel, Well done! Probably see you around the local lanes? Quote Link to comment Share on other sites More sharing options...
Flappa Posted February 25, 2005 Share Posted February 25, 2005 BS, One other question: Did you have the headlamp bracket covers fitted? & did you need to remove to adjust headlamps? If fitted do you have these held on with tie-wraps? (I know that's actually 3 questions but hey, who's counting ) Thanks again, F Quote Link to comment Share on other sites More sharing options...
Black Shadow Posted February 25, 2005 Author Share Posted February 25, 2005 Flappa, Yes I did have to fit them with cable ties, my head lamps were tight enough to be able to moved into postion but tight enough to stay there when adjusted so I did not have tio remove them. I did not use the westy ones but I'll take some pic's of these as well and post them up on Saturday. Quote Link to comment Share on other sites More sharing options...
