Big R Posted February 22, 2005 Share Posted February 22, 2005 I’ve got a zetec and a polo radiator. Does anyone know of a source for a silicon hose that will fit onto the bottom radiator connection and avoids the chassis? Quote Link to comment Share on other sites More sharing options...
GWatson Posted February 22, 2005 Share Posted February 22, 2005 I just got one made up a couple of weeks ago from Highbury hoses, fits perfectly. I sent my one away and the sent back a silicon one. Easy as that Highbury Hose Ltd Unit 6 Viking Business Centre 2 High Street Woodville Swadlincote Derbyshire DE11 7EH 01283 217750 Quote Link to comment Share on other sites More sharing options...
Big R Posted February 22, 2005 Author Share Posted February 22, 2005 Thanks for the reply - can you give me a bit more detail? • Is it a one piece from the radiator to the pump? • Does it have any take offs - I need a connection for my heater? • How much? Quote Link to comment Share on other sites More sharing options...
deller Posted February 22, 2005 Share Posted February 22, 2005 If your not sure of length or angles etc. highbury hose do flexible silicon hoses. Phone them up and tell them what you need - they are very helpful and I highly recommend them. Quote Link to comment Share on other sites More sharing options...
GWatson Posted February 22, 2005 Share Posted February 22, 2005 There is a 90 degree angle hose which comes out of the water pump, it is also a reducer either 40mm or 44mm (waterpump) down to 32mm. The 32mm end joins onto the metal pipe which Wesfield supply. This has a T piece incorprotated into it for the return to the expansion tank. There is then a sort of S shaped hose 32mm, which attached form the other end of the pipe to the radiator. This helps to get round the chassis. If you send me your email address I can email you pictures of the pipes. My invoice has: "3pl reducing 90'elbow 40-32mm, 200 legs "S Shaped hose, 32mm bore, 22-mm long I paid about £45 for those, including the 10% extra or black. Hope that helps. Graeme Quote Link to comment Share on other sites More sharing options...
Big R Posted February 22, 2005 Author Share Posted February 22, 2005 Did you also buy a top hose from them? Again, was it one piece and how much ? Quote Link to comment Share on other sites More sharing options...
GWatson Posted February 22, 2005 Share Posted February 22, 2005 Well I use a Raceline waterrail so it's a totally different setup for the top hoses. I don't think it would be possible to get a one piece. Do you have the metal pipe which runs down the side of the car transfering the coolan?? G Quote Link to comment Share on other sites More sharing options...
GWatson Posted February 22, 2005 Share Posted February 22, 2005 Russel, You should have an email from me..If not let me know. G Quote Link to comment Share on other sites More sharing options...
Big R Posted February 22, 2005 Author Share Posted February 22, 2005 Graeme ditto - I've also got the Raceline water rail, but the blue Raceline (Samco) top hose is too short and the wrong angle. It's obviously designed for another radiator or installation (Caterham?). Thanks for your help.. Quote Link to comment Share on other sites More sharing options...
GWatson Posted February 22, 2005 Share Posted February 22, 2005 Ah ok, well you have the bottom end sorted. To confuse things even more, I don't use the Westfield expansion tank. I did away with the T piece I told you about at the bottom end. The 32mm exit from the thermostat housing goes to the top of the radiator and the smaller one goes into an overflow pipe. I'll sent you a few pics of my setup. Hope that helps you. Graeme Quote Link to comment Share on other sites More sharing options...
PhilH Posted February 22, 2005 Share Posted February 22, 2005 While we are talking bottom hoses,my bottom hose ID is much larger than pipe it fits on to.It was ok until it was disconnected for engine removal now it leaks.Have tried 2 jubilee clips with no improvement.Any ideas,(2l Zetec). Phil Quote Link to comment Share on other sites More sharing options...
GWatson Posted February 22, 2005 Share Posted February 22, 2005 There seems to be two sizes of bottom hose at the water pump end. Others on here said it was 44mm, but I measured my old one and it was def only 40mm. Got a 40mm made up and it fits fine. I do know that Highbury hoses usually make 44mm by default, perhaps you need a 40mm Wow, never thought I'd be able to contribute this much to one thread, I am obviusly learning G Quote Link to comment Share on other sites More sharing options...
hilux Posted February 25, 2005 Share Posted February 25, 2005 `Samco` do reducers in many sizes or pipe in many sizes. You can use the hoses to connect the orifices and make the rest up in copper pipe using (15 22 28 35 42 50mm) pipe and bends (cheap as chips) Quote Link to comment Share on other sites More sharing options...
FlatSix2003 Posted March 1, 2005 Share Posted March 1, 2005 Graeme, Is there any chance you could e-mail a couple of pics of your cooling circuit set-up. I have a raceline waterrail fitted. Does your bottom hose go 'outside' the front chsis rail? I've PM'd you my e-mail address. Cheers Jon Quote Link to comment Share on other sites More sharing options...
