1998 R registration Westfield Seight
Factory rolling chassis with TVR 4 litre V8 engine
All new parts
Full photographic record of build
5000 miles only since build – all dry use
Garaged and in immaculate condition
Chrome yellow
Locking boot box
Black powder coated chassis, suspension, lights, screen
Stainless steel exhausts
Dash top crashpad and kick strips
Adjustable black high back seats with 4 point Willans harnesses
Full hood and sidescreens
TVR Power Cross bolted block by Andy Chesman Engineering
Crank tuftrided, polished and balanced
Con-rods shot peened and balanced
ARP big end bolts
SD1 lightened flywheel
Vitesse heavy duty clutch
New camshaft
Cloyes timing chain
RT380 5 speed gearbox
Sierra XR 4 x 4 Limited Slip Diff and half shafts
Long range fuel tank
5 row aluminium radiator with swirl pot and silicon hoses
Electric cooling fan
5 TSW Blade 15 inch wheels with 205/50 Tyres
£11200 ono
contact chris on 07989 494247 or email christopher.white@RWEnpower.com for photos or more info
Pic
  • 2 weeks later...
3.5 Seight Club Sport - 3.5 V8 1st regd. 01/9/99 as V53 EEU due to virtually all new parts and the high quality of construction.
In Navy Blue with Chrome Yellow wings and nose cone with twin side exhausts.
Built by a talented engineer (and cardiologist!;) then checked and setup by the factory prior to the SVA.
Originally designed and built to comply with the requirements of the 750 Motor Club for competition (hence the 3.5 'normally aspirated' engine) but never raced other than 4 track days. In total the car has covered just 5400 miles from new.
A stunning road car with acres of torque/power tamed by a very high quality chassis. the full spec. is too long to list but is summarised below:
Chassis: powder coated racing spec. Super sport fully adjustable, & rose jointed, Koni adjustable shocks f&r, biased brakes with twin m/cylinders,
RAC rollover bar, 4 point harness and high back competition seats.5 Rimstock 100+ Alloy wheels with Yokohama 520/15 tyres. Limited slip diff.
Engine/Gearbox: Professionally designed and built unit from R.P.I. Engineering in Norwich. Cost over £5000 and is;
Based upon a 1985 engine no. and therefore not liable to modern emissions/catalytic converter regs. It also allows side exhusts.
Using a brand new 3.5 litre block (1996) spec., twin SU carbs.,with new high compression pistons (10.5-1), balanced con rods, lightened flywheel, stage 1 heads, competition gaskets, Piper hi torque camshaft, Vernier duplex timing gear, Mallory twin points distributor, Vitesse spec. 3 part clutch.
A fully reconditioned (by the MOD) 5 speed gearbox.
Dyno'd at 200 hp at 5786 rpm and 230 lb ft torque at 3750 rpm.
It would be relatively simple to liberate even more power and torque by going the Weber or other 4 barrel route, (the rest of the engine has been designed for more power) but frankly with the car weighing in at about 720 kgs it makes for a superb fast road car as is.
The car has always been dry garaged and is in superb order throughout.
Is this the same car......or 2 different ad's..... :durr:  :durr:
It's two ads. The first car is yellow, the second blue.
Andy
Andy
That's what I thought......
and I was trying to hint that the second might be better served by placing his own ad'.......
but then I thought that was too obvious, so wondered if I was missing something....
:durr:  :sheep:  :durr:  ???
Given that it's the second poster's first post, I suspect he assumed that all V8s for sale went into here perhaps?
Andy
Andy
indeed!
