mpett Posted February 7, 2005 Share Posted February 7, 2005 Hi there, Had one of the moments of concern last night, having fitted the gearbox to the engine. (Fortunatley the engine is not in the car! The gearbox I have came from a 1.8cvh engine. The engine I have is a 2l pinto 205 block. The clutch and trust plate were on the pinto, the release bearing was still on the gearbox. Will it work, are they compatible?? Cheers for the help. Martin Quote Link to comment Share on other sites More sharing options...
Nick A Posted February 8, 2005 Share Posted February 8, 2005 Do you know what year pinto as later pinto's used type nine gearbox anyway if this is the case would have said if there is a difference i would presume it would be on the clutch arm I may be wrong but i would give it a try Quote Link to comment Share on other sites More sharing options...
