Saltydog!! Posted January 26, 2005 Share Posted January 26, 2005 I am fast approaching the set-up module in the build manual for my 1800 Zetec. Are there any tricky bits to look out for? What have you guys done for items such as Camber & Tracking set-up's, DIY or not? If DIY what tools are used, and how accurate can you be? Is it as straight forward as it appears? Cheers, SD Quote Link to comment Share on other sites More sharing options...
predawson Posted January 27, 2005 Share Posted January 27, 2005 Personally I would set it by eye to get through SVA, MOT then give it to a pro to set up properly once registered. That's what I did. If you have problems with self centering then either toe out or toe in will work depending on your uprights. Only tools you need are a set of spanners and a C-spanner for the ride height adjustment that can be purchased from Westfield cheaply. Quote Link to comment Share on other sites More sharing options...
Mat Jackson Posted January 27, 2005 Share Posted January 27, 2005 Same advice, although get it MOT'd before SVA. They`ll pick up any little bits wrong first to give you a better chance. They should do the tracking for you there and then. BTW Did mine by eye and a bit of string and got it bang on.. more luck than judgement me thinks. Quote Link to comment Share on other sites More sharing options...
