KerryS Posted January 17, 2005 Share Posted January 17, 2005 Where the bonnet moulding rests on the main tub, should there be any foam strip? There seems to be about a micron between the air filter and the inside surface of the bonnet on my Zetec with the elephant's nose air inlet and if the bonnet was just a touch higher it would help. Kerry S Quote Link to comment Share on other sites More sharing options...
cidersurfer Posted January 17, 2005 Share Posted January 17, 2005 Mine has foam strip Quote Link to comment Share on other sites More sharing options...
stubbow Posted January 17, 2005 Share Posted January 17, 2005 Mine also has foam strip but to be honest its not the foam that sets the bonnet height its the pins and locks! Danny Quote Link to comment Share on other sites More sharing options...
KerryS Posted January 18, 2005 Author Share Posted January 18, 2005 Thanks, guys. Kerry S Quote Link to comment Share on other sites More sharing options...
geelhoed Posted January 18, 2005 Share Posted January 18, 2005 Keep in mind that the engine will move around when you drive. I cut the rubber between the airbox and the throttle body (standard blue oval) as short as possible. Quote Link to comment Share on other sites More sharing options...
Saltydog!! Posted January 18, 2005 Share Posted January 18, 2005 I did the same so that inside the rubber tube, the bottom of the intake was touching the top of the TB. I do intend to put foam along the top of the side panels. HTH, SD Quote Link to comment Share on other sites More sharing options...
KerryS Posted January 18, 2005 Author Share Posted January 18, 2005 It's engine movement that concerns me really, especially with inlet on RHS and, I understand, engine will rock to LHS, raising the inlet higher. I have cut down the mating connection to the throttle body and that bit's OK, it's the rubber connection of the air filter to the inlet trunk up near the header tank that's really close. Course, as stubbow says, the foam's got nowt to do with it really. Kerry S Quote Link to comment Share on other sites More sharing options...
