Big R Posted January 11, 2005 Share Posted January 11, 2005 Apologies if this has been discussed before - my Westfield supplied tank is designed for a fuel injected engine, i.e. has a return port and the pick up is in a lowest point of the tank. Do I still need a swirl pot to ensure a constant feed of fuel to the pump, or is the tank design good enough? Quote Link to comment Share on other sites More sharing options...
deller Posted January 12, 2005 Share Posted January 12, 2005 This topic has been discussed a lot on the site. In a nutshell I believe most people who use your set up have no problems on the road but on the track the only way to ensure a constant supply of fuel (with lower fuel levels) is to fit a swirl pot. This is the route I have taken. A search should pick up relevent threads and the reasoning behind fitting a swirl pot. Paul Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2005 Share Posted January 12, 2005 Do I still need a swirl pot to ensure a constant feed of fuel to the pump, Yes to cover all conditions Not if you drive like Blatters Cos it won't make any difference Quote Link to comment Share on other sites More sharing options...
scott beeland Posted January 12, 2005 Share Posted January 12, 2005 Mine (injection tank-) seems to get starvation at less than 1/4 tank at 3 sisters and Curborough. Fit an extra pot while you've got chance I reckon Quote Link to comment Share on other sites More sharing options...
BEN99W Posted January 12, 2005 Share Posted January 12, 2005 Anyone got any pics of a swirlpot installation? I definitely need to fit one - fuel starvation even with over a third of a tank on full brands Hatch circuit and I wasn't even going very quick (well you wouldn't with little fuel getting through... ) Ta Ben Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted January 12, 2005 Share Posted January 12, 2005 I used a Westfield injection tank last year with a "built in" swirl pot and it was just fine (track use only) Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2005 Share Posted January 12, 2005 I used a Westfield injection tank last year with a "built in" swirl pot and it was just fine (track use only) Carbs or fuel injection Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted January 12, 2005 Share Posted January 12, 2005 If I was using an injection tank with swirl pot - then tis most deffo an injection car or it was last time I looked Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2005 Share Posted January 12, 2005 If I was using an injection tank with swirl pot This is also most deffo what I have and had with a carb set up Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted January 12, 2005 Share Posted January 12, 2005 I didn't need it with carbs na na na na na na na na and used a boggo tank Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2005 Share Posted January 12, 2005 Soo you had to buy another tank Ha Ha Ha Ha Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted January 12, 2005 Share Posted January 12, 2005 A mere bagatelle in the overall project and I sold my old one anyway na na na na na na na na na na na Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 12, 2005 Share Posted January 12, 2005 So the old one goes faster now Quote Link to comment Share on other sites More sharing options...
scott beeland Posted January 12, 2005 Share Posted January 12, 2005 Oh that's gotta sting Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted January 13, 2005 Share Posted January 13, 2005 does when Wotbox drives it Quote Link to comment Share on other sites More sharing options...
