Vincent Langan Posted January 4, 2005 Posted January 4, 2005 I am hoping that someone can answer the following questions: 1. Are the bellhousing bolt patterns the same for a 1.6 vs. 2.0? 2. I looked under the valve cover of my 1.6 and noticed what appeared to be rust toward the front of the engine? When I pulled the plugs, I had rust near the bottom. Is this normal? Good luck trivia masters..... cheers, Vince Quote
Westfieldman Posted January 4, 2005 Posted January 4, 2005 Bellhouse bolt pattern are the same on X flow Pinto CVH Zetec [but some have different blocks] The bolt pattern changes for the Duratec Quote
neilwillis Posted January 4, 2005 Posted January 4, 2005 It's not unusual to have a little rust around the plugs. Water collects down there. You'll probably find it is just superficial rust on the bolt heads, and nothing to worry about. Quote
Ian Podmore Posted January 4, 2005 Posted January 4, 2005 Why use a 1600 Zetec? The engine is very restrictive, even when compared to a standard 1800 or 2000. Quote
stu999 Posted January 4, 2005 Posted January 4, 2005 One of the 1600 'Zetec' motors have an alloy block, and is very responsive to tuning IIRC... Have a look here... Quote
Mike-SEiW Posted January 4, 2005 Posted January 4, 2005 From Shawspeed: In conjunction with the 2.0 Duratec HE this is in our estimation one of the most significant engines to be introduced to the kit car market for a number of years. The engine is found in the Focus, Fiesta and 1600 Puma. Being of all alloy construction and very compact dimensions the engine is extremely light in weight. The head has good ports as standard and the standard valves can be retained for up to 220bhp. The engine already has a healthy competition background a derivative having been used in the Puma Super 1600 cars as campaigned by Ford RallyeSport in the Junior World Rally Championship. The Sigma engine is also installed in the latest Fiesta Super 1600 rally car which will make it's competition debut later this season. Quote
Ian Podmore Posted January 4, 2005 Posted January 4, 2005 Thats not a 'Zetec' as we would normally know it.... Thats from the 'Duratec' or Yamaha range of Ford engines, hence the 'Zetec SE' label. Ford do seem to enjoy trying to confuse.... Quote
Blatman Posted January 4, 2005 Posted January 4, 2005 John Loudon has one. I think it's in more bits than Ford/Yanaha intended right now though... Quote
