nathanD Posted December 26, 2004 Share Posted December 26, 2004 hello everyone ive recently started to put the aliminium panels ont my car, the panels in the kit were all pre drilled however ive noticed in the manual that you need to drill and fix at 50mm centers, but on some of my panels ( rear scuttle panel) the holes are in excess will i need to put more holes in the panels or will just fixing them were there are holes be ok cheers nathan Quote Link to comment Share on other sites More sharing options...
perksy Posted December 26, 2004 Share Posted December 26, 2004 As long as their not Excessively spaced you should be ok. You'll be sealing them with clear silicon sealant anyway Quote Link to comment Share on other sites More sharing options...
Leon B Posted December 27, 2004 Share Posted December 27, 2004 or some kind of bonding agent Quote Link to comment Share on other sites More sharing options...
Nick A Posted December 27, 2004 Share Posted December 27, 2004 thought i have read somewhere not to use silicone sealant as it causes corrosion Quote Link to comment Share on other sites More sharing options...
scott beeland Posted December 27, 2004 Share Posted December 27, 2004 only if you use the "bathroom" type that contains fungicides....Not good to chassis Quote Link to comment Share on other sites More sharing options...
chazpowerslide Posted December 28, 2004 Share Posted December 28, 2004 I used Sikaflex on mine. It sticks anything to just about everything else and is described as a "semi structural sealant" Use poly/latex gloves when using it, it took me weeks to get it off my hands. Chaz. Quote Link to comment Share on other sites More sharing options...
smithydar Posted December 29, 2004 Share Posted December 29, 2004 or if you havent any disposable gloves.paint thinners work just fine. Quote Link to comment Share on other sites More sharing options...
