Steve20 Posted December 26, 2004 Share Posted December 26, 2004 Looking to fit a carbon fibre dash from day 1, however have heard mixed reports on SVA compliance. Does anybody have a clear position on this? I am planning to use either Norwich or Leighton Buzzard for the SVA if that makes a difference. Cheers Steve Quote Link to comment Share on other sites More sharing options...
wills-Megablade Posted December 26, 2004 Share Posted December 26, 2004 Im building my first kit so havent done the sva bit yet, however all my kit has been supplied direct from w/f including my upgraded carbon fibre dash. nothing was said in preparation for test and they knew its for the road so i assume its ok. I have heard of people having to loose the sharp edges with a dremmel and/or rubber surround just for the test..... Quote Link to comment Share on other sites More sharing options...
p.thomas Posted December 26, 2004 Share Posted December 26, 2004 I fitted a carbon fibre dash and it passed the SVA at Cardiff. There was only one issue which I resolved beforehand. I used VDO guages and had to fit a large temporary Rubber O ring around the outside of the 52mm guages because they were not radiused. The normal dash would have been soft enough to have covered this. Hope this helps, Peter. Quote Link to comment Share on other sites More sharing options...
Graham Posted December 26, 2004 Share Posted December 26, 2004 You might have trouble with the bottom radius, see here, about half way down... SVA Test But I doubt if you'll be *that* unlucky! Mine is the Westfield standard C/F dash and according to my SVA man the radius is only 18.5 mm, but only in the corners! Apart from that, watch for the radius on any guages not in the safe area. Graham. Quote Link to comment Share on other sites More sharing options...
Steve20 Posted December 27, 2004 Author Share Posted December 27, 2004 Thanks guys, will be carbon fbre dash finished nicely with "o" rings on the instruments but hopefully without the need for Graham's designed water pipe and velcro! Appreciate the help and have a great New Year. Steve Quote Link to comment Share on other sites More sharing options...
P W Posted December 27, 2004 Share Posted December 27, 2004 Hiya steve - not sure if you already have the dash, if not worth calling paul at playskool (tel - 01274 680100) I've just fitted one - as have many others Cheers, Paul Quote Link to comment Share on other sites More sharing options...
Rob Navin Posted December 27, 2004 Share Posted December 27, 2004 I've just fitted one *cough* Quote Link to comment Share on other sites More sharing options...
