Chester Posted September 10, 2003 Share Posted September 10, 2003 Hi, Does anyone know how to remove the steering wheel on a 2000 Ford Fiesta that has a drivers air bag fitted? The steering wheel is offset and the other half would like it putting back on straight. Cheers Mark Quote Link to comment Share on other sites More sharing options...
S8ight Posted September 10, 2003 Share Posted September 10, 2003 just get the tracking done. Quote Link to comment Share on other sites More sharing options...
7SE Posted September 10, 2003 Share Posted September 10, 2003 [lateral thinking] Adjust the tracking with the steering wheel set straight [/lateral thinking] Quote Link to comment Share on other sites More sharing options...
7SE Posted September 10, 2003 Share Posted September 10, 2003 just get the tracking done. Sorry, for some reason I didn't see that Quote Link to comment Share on other sites More sharing options...
Chester Posted September 10, 2003 Author Share Posted September 10, 2003 That's what has caused the problem in the first place. The tracking was done but now the wheel is offset. Mark Quote Link to comment Share on other sites More sharing options...
neilwillis Posted September 10, 2003 Share Posted September 10, 2003 The people who adjusted the tracking didn't centre the steering wheel before they adjusted it. What it means is that the wheels and the steering wheel are no longer in synch. It isn't difficult to put right by getting the tracking re-adjusted with the wheel centred. Quote Link to comment Share on other sites More sharing options...
Ian Podmore Posted September 10, 2003 Share Posted September 10, 2003 Take it back to where it was adjusted and get them to do the job properly? Quote Link to comment Share on other sites More sharing options...
stu999 Posted September 10, 2003 Share Posted September 10, 2003 Yup cause if you take the steering wheel off, you will find that it isnt on a spline, but on a hexagonal shaft, so unless it's 60 deg out, it's a waste of time anyway. IMO take it back to the garage. it sounds like they've adjusted the one side only...... Quote Link to comment Share on other sites More sharing options...
david.c Posted September 10, 2003 Share Posted September 10, 2003 Take it back to where it was adjusted and get them to do the job properly? Seconded. Unless they offered to screw up your steering wheel alignment at no extra cost David Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 10, 2003 Share Posted September 10, 2003 take it back an get the track set correctly the steering wheel is not on splines as nornal but on a hexegon shaped shaft as already mentioned so if you get the wheel off you probably will still end up with the wheel out does sound like only one track rod has been adjusted Quote Link to comment Share on other sites More sharing options...
Bazzer Posted September 10, 2003 Share Posted September 10, 2003 It also means that the bump steer on each wheel will be different. As the effective length of the steering arms will be different. Probably not as much of a problem on the wifes Fiesta as it would be on the Westie :-) Bazzer Quote Link to comment Share on other sites More sharing options...
ChrisG Posted September 10, 2003 Share Posted September 10, 2003 "wifes Fiesta" ?? I thought she had a Leon, and you had the Fie..... Quote Link to comment Share on other sites More sharing options...
