langy Posted December 18, 2004 Share Posted December 18, 2004 E-bay Nothing to do with me................ yet Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted December 18, 2004 Share Posted December 18, 2004 This engine is a brand new 2ltr ford duratec engine with only 150 run in miles. It was dynoed with throttle bodies at 262BHP and when fully run in 270BHP is expected Modifications done are:- Reprofiled Large Cams Set Springs Ported Fast Road Head Skimmed Head Pocketed and Balenced Pistons Big End Bolts Matched Inlet Manifold to Head and Ports Set Valve Shims [the Duratec does not have valve shims in it does he mean he has had to replace the cam follower caps that are indeed the tappet shims if so why as most of the better camshaft companies are producing cams with the same bace circle] Baffled Wet Sump Lightened Flywheel Thats quite an optomistic dyno And why has he added 1/2 kg buy painting an alloy block Quote Link to comment Share on other sites More sharing options...
timd Posted December 18, 2004 Share Posted December 18, 2004 And why has he added 1/2 kg buy painting an alloy block Maybe he likes the colour blue, and isn't so anal about weight saving that a few grams here or there is unimportant. Just a thought.. Quote Link to comment Share on other sites More sharing options...
