mad lon Posted December 7, 2004 Posted December 7, 2004 12" wooden,6" perspex,queen Victoria or Wotsis the Hun for instance....Rules,rules,b*****k to the rules....who said that? Rule No 1...There are no rules.....who said that? Quote
conibear Posted December 7, 2004 Posted December 7, 2004 Rules,rules,b*****k to the rules....who said that? Rule No 1...There are no rules.....who said that? you did Quote
mad lon Posted December 7, 2004 Author Posted December 7, 2004 Rules,rules,b*****k to the rules....who said that? Rule No 1...There are no rules.....who said that? you did bl****ell Quote
Gromit Posted December 7, 2004 Posted December 7, 2004 "Dont pi55 on an electric fence" Always worked for me. Quote
pistonbroke Posted December 7, 2004 Posted December 7, 2004 oldman I just realised you got your name spelled rong Quote
mad lon Posted December 7, 2004 Author Posted December 7, 2004 "Dont pi55 on an electric fence" Always worked for me. Once knew a chap who did that...cured his impotence in a split second Quote
oioi Posted December 7, 2004 Posted December 7, 2004 thou shalt not commit adulthood (who sang that?) Quote
mad lon Posted December 7, 2004 Author Posted December 7, 2004 oldman I just realised you got your name spelled rong Wot took yer Broke n' p******** Quote
mad lon Posted December 7, 2004 Author Posted December 7, 2004 thou shalt not commit adulthood (who sang that?) Wos it Manfred Man Quote
CrashBangWallop Posted December 9, 2004 Posted December 9, 2004 I follow these rules at work. The ten rules of cartoon animation: - Cartoon Law I ============= Any body suspended in space will remain in space until made aware of its situation. Daffy Duck steps off a cliff, expecting further pastureland. He loiters in midair, soliloquizing flippantly, until he glances to look down. At this point, the familiar principle of 32 feet per second per second takes over. Cartoon Law II ============== Any body in motion will tend to remain in motion until solid matter intervenes suddenly. Whether shot from a cannon or in hot pursuit on foot, cartoon characters are so absolute in their momentum that only a telephone pole or an outsize boulder retards their forward motion absolutely. Sir Isaac Newton called this sudden termination of motion the stooge's surcease. Cartoon Law III =============== Any body passing through solid matter will leave a perforation conforming to its perimeter. Also called the silhouette of passage, this phenomenon is the specialty of victims of directed-pressure explosions and of reckless cowards who are so eager to escape that they exit directly through the wall of a house, leaving a cookie-cutout-perfect hole. The threat of skunks or matrimony often catalyzes this reaction. Cartoon Law IV ============== The time required for an object to fall twenty stories is greater than or equal to the time it takes for whoever knocked it off the ledge to spiral down twenty flights to attempt to capture it unbroken. Such an object is inevitably priceless, the attempt to capture it inevitably unsuccessful. Cartoon Law V ============= All principles of gravity are negated by fear. Psychic forces are sufficient in most bodies for a shock to propel them directly away from the earth's surface. A spooky noise or an adversary's signature sound will induce motion upward, usually to the cradle of a chandelier, a treetop, or the crest of a flagpole. The feet of a character who is running or the wheels of a speeding auto need never touch the ground, especially when in flight. Cartoon Law VI ============== As speed increases, objects can be in several places at once. This is particularly true of tooth-and-claw fights, in which a character's head may be glimpsed emerging from the cloud of altercation at several places simultaneously. This effect is common as well among bodies that are spinning or being throttled. A `wacky' character has the option of self-replication only at manic high speeds and may ricochet off walls to achieve the velocity required. Cartoon Law VII =============== Certain bodies can pass through solid walls painted to resemble tunnel entrances; others cannot. This trompe l'oeil inconsistency has baffled generations, but at least it is known that whoever paints an entrance on a wall's surface to trick an opponent will be unable to pursue him into this theoretical space. The painter is flattened against the wall when he attempts to follow into the painting. This is ultimately a problem of art, not of science. Cartoon Law VIII ================ Any violent rearrangement of feline matter is impermanent. Cartoon cats possess even more deaths than the traditional nine lives might comfortably afford. They can be decimated, spliced, splayed, accordion-pleated, spindled, or disassembled, but they cannot be destroyed. After a few moments of blinking self pity, they reinflate, elongate, snap back, or solidify. Corollary: A cat will assume the shape of its container. Cartoon Law IX ============== Everything falls faster than an anvil. Cartoon Law X ============= For every vengeance there is an equal and opposite revengeance. This is the one law of animated cartoon motion that also applies to the physical world at large. For that reason, we need the relief of watching it happen to a duck instead. Quote
