Twin Engine Z-Car Westfield
Fluke's Twin engine Westfield SEiW
1999 full rebuild in 2001
Chassis
Westfield SEi Wide body '99 chassis
Strengthed and braced to accept 2 engines and provide sufficient stiffness to cope with the increased power
Caged FIA/MSA Homologated T45 Roll Cage.
Floor mounted pedales
Engine
2x Kawasaki ZX9R engines
2x Pipercross filters
2x Z-cars carbs
2x Tony Law exhaust manifolds
2x Wunoffs silencers (Re packed and messured @ 103DB)
2x Carbon Fibre silencers (Sounds just like a F1 Car)
Hayward and Scott stainless steel polished brackets and custom pipes
Transmission
Z-Cars transfer box to combine and transmit drive from the two six speed sequential boxes
Quaife ATB Alloy LSD diff 7" with Quaife Flanges. (fresh rebuild and seals)
Pumped oil cooling circuit and bearing retainer mods to help cooling and life of Transfer box
2x Bailey Morris custom propshafts, with torque tubes
Cockpit
Plays-Kool Seats
Willians Harness's
Carbon Fibre Tunnel cover
Custom made dash board
Elliot Tachos
Sparco 260mm D shape removeable stearing wheel
Brake System
Willwood Alloy 4 pot calipers
280mm vented crossed drilled disks
Willwood bias adjuster.
Engine bay
Westfield high efficieny V8 alloy radiator
TAS 2.2 quick turn stearing rack
Some Earls braded hoses with blue and red connector
Outside
ZX Orange body work
Ducted nosecone
Removeable rear arches
Cycle wings
Aero flush fuel cap
Cat motorsport Polly bushes
Avo alloy ajustabe dampers.
Tim Duncan Aero screen
RFX Revolution split rims wheels
Toyo Proxes T1-S tyres
Misc
Custom made ducting
Custom made Anti-roll bars
This car is the best of the best, you will not find better.
Considerable time, effort and money has been spent on this car improving it's performance, handling and reliabilty over and well beond the orignal Z-Car spec.
This car has only been on local dry trips round the block since I have been owning this car, the electrics have been up graded and made neater as have some pipe work, the Diff has been rebuild with a new Crownwheel and pionon making it much more user friendly, but to be fair the car was spot on when I recived it.
Work comitments are no longer alowing me to keep this car.
Offers around the £15,000 mark
0780 123 3857
01245 257794
jan@fluke-motorsport
I'd have kept that one and sold the carbon one
FWIW, the original silencers were Wunoffs not westfield items Jan.
Good luck with the sale..
Thanks Tim. You know you miss it and want it back it.
Just B4 Christmas is not a good time to sell a car I guess.
:xmas:
Not for 15k I don't! :p;)
TBH, I think you're gonna struggle to shift it. Bear in mind I'd advertised it for several months before some pikey finally got interested, and that was in the summer. :( Could be better off mothballing it and trying again in the spring maybe?
If it helps though, ALL the interest came off the back of it being advertised on ebay. Not a peep from folk on here - the results of your poll kinda indicate just how frightened this lot are of that car.. ;) also no response from any of the other places it was advertised.
I have to say this is one blindingly quick car - very impressive indeed!
Sorry Jan but I'm not in the market for another!
Kevin
  • 2 weeks later...
My move to OZ has been called off.
So the car is no longer for sale.
Woooh  :D  :D
