davish Posted November 21, 2004 Share Posted November 21, 2004 i`m fitting a 4age in my seiw and want to fit a type 9 gearbox do i fit a long or short input shaft type? is there any advantage to either one. Quote Link to comment Share on other sites More sharing options...
davidgh Posted November 21, 2004 Share Posted November 21, 2004 Subject to you using one of the usual bell housings (like Raw), I think it's the short shaft you need. A phone call to the excellent guys at BGH Geartech will tell you all you need to know. HTH Quote Link to comment Share on other sites More sharing options...
Blatman Posted November 22, 2004 Share Posted November 22, 2004 The only advantage to be gained using a standard type 9 is to go for one fitted to a 2.8i Capri. It'll have a *slightly* longer 1st gear. Not by much mind, and it's no substitute for getting a properly long 1st, but it'll be a (very) little better than the Sierra ratios... Quote Link to comment Share on other sites More sharing options...
