Blatman Posted November 23, 2004 Share Posted November 23, 2004 Doesn`t that have the primary and secondary ports the wrong way around?Ie frount port is for the back brake and vice versa? I think you're right... It'd be well worth while checking it out to be sure... Quote Link to comment Share on other sites More sharing options...
Eddy5 Posted November 23, 2004 Share Posted November 23, 2004 6)"This panel may need to be flexed to fit" Ho ho ho....oops....I'm sure we can flatten that kink out....hmmmmm It's all relative with the build manual, at least we get one. When my mate started building his Grinall 6 years ago he didn't get any instructions, just the bits in a big bag. He spent a day at the factory taking pictures, making notes and diagrams. Quote Link to comment Share on other sites More sharing options...
Mat Jackson Posted November 23, 2004 Share Posted November 23, 2004 Doesn`t that have the primary and secondary ports the wrong way around? Ie frount port is for the back brake and vice versa? I think you're right... It'd be well worth while checking it out to be sure... Wow, I feel special now!!! I made a technical comment and it got endorsed by blatters!!!! Quote Link to comment Share on other sites More sharing options...
KerryS Posted November 23, 2004 Author Share Posted November 23, 2004 Quote (Blatman @ Nov. 23 2004,11:42) Quote Doesn`t that have the primary and secondary ports the wrong way around? Ie frount port is for the back brake and vice versa? I think you're right... It'd be well worth while checking it out to be sure... Wow, I feel special now!!! I made a technical comment and it got endorsed by blatters!!!! Kerry S Quote Link to comment Share on other sites More sharing options...
phelpsa Posted November 23, 2004 Share Posted November 23, 2004 I'm 13 and am building a motorbike power Locost (with a bit of help from dad when it comes to undoing sierra rear hubnuts:D ). Started when I was 12 (yr7)and it has been a huge learning experience. Learnt how to MIG weld, use an angle grinder without damaging myself and many other things involved in building a chassis. And don't worry, every dimension and every weld is checked by my dad (guess where I got the gene from ), so it won't be three inches longer on one side than the other! Also learnt that 20ft of rectangular steel is only 19 ft when chopped up! Adam Quote Link to comment Share on other sites More sharing options...
