Jan Coombes Posted August 7, 2003 Share Posted August 7, 2003 I have ripped my belt on my dry sump pump must have been a stone or something. (Under tray going on soon) But how do I change it, if I slide it off, will the new one just slide back on? Quote Link to comment Share on other sites More sharing options...
oioi Posted August 7, 2003 Share Posted August 7, 2003 this sbd/pace system? if so it just slides on/off as it is not under tension. or at least mine does...... Quote Link to comment Share on other sites More sharing options...
moomin Posted August 7, 2003 Share Posted August 7, 2003 you should be able to twist the belt through 90 degrees by hand, so I would imagine it will just slide on and off (once you have removed any restraining bits and bobs). sounds like you may have been lucky to spot it before bad things happen! moomin Quote Link to comment Share on other sites More sharing options...
Jan Coombes Posted August 7, 2003 Author Share Posted August 7, 2003 mine is a caterham one, and it feels quite tight, think I can get it off, but "I may have a problem getting it on" Not really something that I am used to Quote Link to comment Share on other sites More sharing options...
hilux Posted August 7, 2003 Share Posted August 7, 2003 Grease the belt Quote Link to comment Share on other sites More sharing options...
ACW Posted August 7, 2003 Share Posted August 7, 2003 if the tension is correct it should slide off the pulley. otherwise normally there is a slotted hole under the mounting to allow the tension to be relieved. The belt should be a lot slacker than you think... Quote Link to comment Share on other sites More sharing options...
