chunk Posted October 31, 2004 Share Posted October 31, 2004 Hi, my diff seems to have a hole in the top , should it have a dipstick or something in it? it is just open to atmosphere, I think its a sierra diff. thanks chris Quote Link to comment Share on other sites More sharing options...
adhawkins Posted October 31, 2004 Share Posted October 31, 2004 Is that where the breather should go? Mine has a very small, rigid pipe coming up from the top of the diff. Andy Quote Link to comment Share on other sites More sharing options...
Steve20 Posted October 31, 2004 Share Posted October 31, 2004 When looking at the back of the diff (from rear of car) there should be a small hole on the top right hand side for the breather pipe. The breather uses a plastic fitting about 10mm long to which you need to add a rubber pipe 100mm long. The diff needs to breathe to atmosphere. Put my diff in yesterday and had to file off the bottom right hand corner to provide 4mm clearance against the left hand chassis rail, according to Westfield this is a common requirement. Other thing to watch out for is that the late 7.5 diffs used bolts for the top mountings and not the long stud, not a problem, just make sure you have the correct fixings before starting. Regards Steve Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted October 31, 2004 Share Posted October 31, 2004 to which you need to add a rubber pipe 100mm long. Make it much longer if you intend to go on track Quote Link to comment Share on other sites More sharing options...
highwayman Posted October 31, 2004 Share Posted October 31, 2004 Chunk , breathers available for just over a pound from Ford parts department Dave Quote Link to comment Share on other sites More sharing options...
chunk Posted October 31, 2004 Author Share Posted October 31, 2004 Thanks for all the responses does this small plastic pipe just push into the hole as it doesn't seem to have a thread? Mark, how long does the pipe have to be for track use and does it just point upwards or does it need rooting somewhere Quote Link to comment Share on other sites More sharing options...
Terry Everall Posted October 31, 2004 Share Posted October 31, 2004 Mine is only small and I go on track a lot with no problems Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted October 31, 2004 Share Posted October 31, 2004 Route a longer pipe around the back end of your chassis and have the end pointing up as high as poss within "bootbox area" about 2ft (600mm). Plastic pipe is cheap Quote Link to comment Share on other sites More sharing options...
Steve and Becky Posted October 31, 2004 Share Posted October 31, 2004 What benefit does this long pipe have? MMMmmmmmmm Quote Link to comment Share on other sites More sharing options...
Kevin Wood Posted November 1, 2004 Share Posted November 1, 2004 To Answer Chunk's question the breather comprises a plastic fitting which is a push fit into the hole in the diff. This has a small barb on it for a length of rubber hose approx 5mm diameter at a guess. A visit to the local Ford parts department should do it. Failing that Westfield will sell you one. Kevin Quote Link to comment Share on other sites More sharing options...
Arm Posted November 1, 2004 Share Posted November 1, 2004 What benefit does this long pipe have? MMMmmmmmmm Acts as a small reservoir - catches and allows diff oil and fumes to drop back into the diff. Mine will work with the standard short pipe everywhere except on high grip long LH corners for example Mira. With the short pipe oil can pump out with the long pipe it doesn't. Not exactly scientific though. Quote Link to comment Share on other sites More sharing options...
Turbo Tommo Posted November 1, 2004 Share Posted November 1, 2004 Mine is only small and I go on track a lot with no problems What about the pipe tho' Tel? Quote Link to comment Share on other sites More sharing options...
scott beeland Posted November 1, 2004 Share Posted November 1, 2004 What benefit does this long pipe have? MMMmmmmmmm Acts as a small reservoir - catches and allows diff oil and fumes to drop back into the diff. Mine will work with the standard short pipe everywhere except on high grip long LH corners for example Mira. With the short pipe oil can pump out with the long pipe it doesn't. Not exactly scientific though. Mine did the very same at aintree. Better now since much longer tubing fitted Quote Link to comment Share on other sites More sharing options...
scruffythefirst Posted November 1, 2004 Share Posted November 1, 2004 Windscreen washer tubing fits quite nicely onto the breather Quote Link to comment Share on other sites More sharing options...
chunk Posted November 1, 2004 Author Share Posted November 1, 2004 Once again thanks for the advice is the allen head screw at the back of the diff the one used for filling and checking the oil level Quote Link to comment Share on other sites More sharing options...
