Eddy5 Posted October 30, 2004 Posted October 30, 2004 Picked up my Dad's Westy yesterday, all very exciting. Whilst watching a Racing Car is born, apart from noticing how much he's had done for him already, also noticed how the holes were already cut for the exhaust. We both though that's looks a bit tricky, so we'd consult the instructions. Absolutely no mention of how to fit the exhaust. Our best guess is it should be in Module 5. And there is a completely blank page on 25 (No page number or anything) where it could be located. Has anyone else seen the instructions for the exhaust? I've already printed off the very helpful instructions from Oakwood_Data for hole cut out. Just wondered really if our instructions are missing something. Quote
Big R Posted October 30, 2004 Posted October 30, 2004 Hi Eddy I didn't get any instructions either - common sense dictates that you start with a small hole and enlarge to suit. I haven't actually done this yet, so I'd be interested to see how you get on. Quote
deano.1 Posted October 30, 2004 Posted October 30, 2004 Youd be well advised to take a look at Steppenwolfs build site, he details a lot of stuff like this! Quote
Gromit Posted October 30, 2004 Posted October 30, 2004 Try tapeing a sheet of carboard roughty in the place where the manifold comes throught the chassis rails and hack that about until you get a good fit with the manifold, then simply transfer that pattern onto your tub. Unless your tub is already riveted on that is. Other than that its as said previously, start with a small hole and work slowly from there. Best of luck. Phil Quote
steppenwolf Posted October 30, 2004 Posted October 30, 2004 Youd be well advised to take a look at Steppenwolfs build site, he details a lot of stuff like this! Here to be precise Quote
Glen H Posted October 30, 2004 Posted October 30, 2004 Best bet is to fit the engine, then temporary fit the exhaust before fitting the main body tub, take measurements from some of the chassis rails, remove exhaust, then transpose the measurements onto the body once fitted. Quote
Mat Jackson Posted November 1, 2004 Posted November 1, 2004 I had instructions in my manual!!!! I can photocopy them and post them if required. Mine included full dimensions, although I did need to do a bit of filling. Don`t be put off with cutting the holes, it is very very easy. And worse case, repairs can be carried out. I was petrified when I first cut into mine, but now its no problems. Quote
