KerryS Posted October 6, 2004 Share Posted October 6, 2004 Nigel I agrre with Geelhoed - use 4.1mm drills - believe me I have just finished this part of the job as you know. I got a small box of 10 drills for a few ££ from a local tool shop - as in proper tool shop, not B&Q type tool shop. I have used them randomly from the box and broken one, which was a bit of a b****r as it was the one I had shortened to do one of the awkward holes - and there are some - so I had to shorten another one. Kerry S Quote Link to comment Share on other sites More sharing options...
johnnystorm Posted October 7, 2004 Author Share Posted October 7, 2004 Cheers for that! Off to search out 4.1 bits..... Quote Link to comment Share on other sites More sharing options...
predawson Posted October 7, 2004 Share Posted October 7, 2004 One or maybe two bits should be sufficient provided you keep the drill speed down and apply decent pressure. Drill bit will be cutting then not grinding so won't overheat and won't go blunt. Quote Link to comment Share on other sites More sharing options...
corsechris Posted October 7, 2004 Share Posted October 7, 2004 RS (or Electromail) do nice, short 4.1 drills designed for drilling sheet metal...they have a wee pointy pip on the end to self-centre on. Work a treat on ali, steel & FRP or even a sandwich of all 3 at once. Quote Link to comment Share on other sites More sharing options...
