geofff Posted September 15, 2004 Share Posted September 15, 2004 Hi All, Does C/F cut the same as GRP? Fine tooth hacksaw with masking tape over the bit I'm cutting? Any tips welcome! Thanks Geoff Quote Link to comment Share on other sites More sharing options...
Blatman Posted September 15, 2004 Share Posted September 15, 2004 Sounds OK to me. Final shaping with a file, no worries. Wear a mask and gloves though. Carbon fibre splinters are a sod... Quote Link to comment Share on other sites More sharing options...
geofff Posted September 15, 2004 Author Share Posted September 15, 2004 Hi Blatman, Should I edge it with a bit of rubber strip where my dash and boot cover will meet the GRP bodywork? Stop it scratching when on the move. Ta Geoff Quote Link to comment Share on other sites More sharing options...
felters Posted September 15, 2004 Share Posted September 15, 2004 Geoff - the dust off CF is awful stuff - try and use a decent vacuum cleaner to suck the dust away as you're working. The dash and boot cover shouldn't be moving about. I haven't put a rubber edge on mine. Good luck! Quote Link to comment Share on other sites More sharing options...
mb893 Posted September 15, 2004 Share Posted September 15, 2004 Masking tape both sides/fibre cutting blade & jigsaw/Dremel/HD Face mask/Goggles. I've put rubber edge on my boot box cover - 1mm thick CF is akin to a razor Quote Link to comment Share on other sites More sharing options...
Blatman Posted September 15, 2004 Share Posted September 15, 2004 Nope, no rubber edge on my dash or boot panels either... Quote Link to comment Share on other sites More sharing options...
geofff Posted September 15, 2004 Author Share Posted September 15, 2004 Hi, I'll see if I get nice smooth edges when I've cut it and then edge or not as appropriate. Thanks Geoff Quote Link to comment Share on other sites More sharing options...
felters Posted September 15, 2004 Share Posted September 15, 2004 am I the only guy around here with a CF/Nomex honeycombe boot lid cover? Quote Link to comment Share on other sites More sharing options...
Blatman Posted September 15, 2004 Share Posted September 15, 2004 Nope... Quote Link to comment Share on other sites More sharing options...
