deano.1 Posted September 2, 2004 Posted September 2, 2004 im just at the stage of mating my mt75 up to my 2.0 zetec, when i took the mtx75 gearbox off the engine there was a thin plate between the two. Do i need a plate for my combination and if so which one? Cheers, Dean Quote
ROC Posted September 2, 2004 Posted September 2, 2004 Dean, I put one between my engine and box as otherwise you get left with some large holes around the exposed flywheel. Even with the plate there are still some holes left, which I just covered with some ally sheet. The plate is a Sierra part which you can get from a Ford parts dept. If you need a part number I can try and find it later. HTH Rich. Quote
deano.1 Posted September 2, 2004 Author Posted September 2, 2004 yes plz roc, or just wether its from the pinto or the twin cam engine! cheers mate Quote
deano.1 Posted September 3, 2004 Author Posted September 3, 2004 Just a little update, when i put it all together with the raceline sump it turns out that there is only one small ish hole on the inlet side. The sump covers all the bottom! Quote
ROC Posted September 3, 2004 Posted September 3, 2004 You guys with those posh sumps, makes my poor old cut and shut job look very inferior Quote
deano.1 Posted September 5, 2004 Author Posted September 5, 2004 Well on the subject of sumps, W/F now do a proper cast sump which I saw at Donnington on Saturday. It is priced around £200 ish which seems cheaper than a cut and shut to me! Quote
