Hi, i have a 1.6 pinto at the moment and was thinking about putting a kent fr32 cam in. Do i need double value spring or can i still use the standard ones ?. many thanks jonno
Kept the single springs in mine (2.1 Litre), but ask Burtons when you buy the cam kit.....Its giving me a very driveable 150 bhp ay flywheel  :D
What else have you had done to your engine, I just want gauge what I should expect, bhp wise, from mine.
Dan
Scholar ported, big valve head, vernier cam wheel, lightened, balanced, over bored bottom end, twin 45s...engine is for sale at moment due to planned Atmo Cossie conversion over the winter......
It just seemed a bit low 150bhp. I have seen a dyno of my engine in a similar sort of spec apart from it is still a 2.0L and this put out 156bhp at the flywheel on a DGV carb.
Dan
