sgilks Posted August 24, 2004 Share Posted August 24, 2004 Folks, End of summer sale! - 2 more sets to go... Pair of DHLA45s with 36mm chokes (set 6 in the photo link below) £160 Pair of DHLAs with 36mm chokes (set 5 in the photo link below) - needs one float lid screw replacing £155 Set of 50mm ram pipes to suit above £25 Set of 50mm deep pipercross filters to suit above £25 (includes a set of ram pipes cut down to 30mm to suit these filters. They can be collected from Coventry area or buyer pays p&p. Pictures for all the above at: http://sgilks.users.btopenworld.com/carbs/ These carbs have been used on 160 or 180hp 2 & 2.2 litre lotus 912 engines so will be jetted accordingly. Prior to use I would always recommend a strip and rebuild to replace the fuel pump diaphragm, o-ring seals and needle valves so please build this into your plans - a kit to overhaul a pair of carbs is ~£20 from Paul Mattey sportcars (available elsewhere as well) and takes about 40mins with no special tools required. Also, unless you are an expert with carbs and engine setup then budget on a rolling road session or time with someone who can setup sidedraught carbs to give you the best from them and your engine. More details on the carbs and selection are available at: http://www.racecar.co.uk/dellorto/carcarburettors/dhla.htm and http://members.aol.com/_ht_a/DVAndrews/dellorto.htm Stuart 07801 028138 / sgilks@btinternet.com Link to comment Share on other sites More sharing options...
