Well winter is coming and the budget is being drawn up for those long winter nights in the garage :D
Im looking to strip a good few killos this winter after a weigh in at Ash's (it was like a flyweight against a heavy weight :( )My car was around 760kg with me in it. The car is a SEiw, 2.0 vx. To date I have put fibre glass seats in , polo rad and ordered light weight brake discs. The heater will be coming out :p  :p
Any suggestions/ ideas of shedding  more killos ???  ???
Stu
  • Replies 53
  • westy
    7
  • stu.graham
    6
  • Rob Navin
    4
  • Westfieldman
    4
Stu
My car is fairly light.
Feel free to have a look at what else you can do when we get to Ty-croes.
There are savings that cost cash and some that just cost time ( as long as you have got lots of drills and hacksaw blades )
Rob
Tried that one :D  :D , plus the vindaloo the night before :blush:  :blush:
Stick a bike engine in it  :devil:  :D
Fit a Duratec should be 40kg's lighter
Race leader  alloy uprights
Nitron dampers
SBD widetrack
GKN lightened lobo joints
SPA steering wheel
R500 wheels
ACB10's
Bin all the things you don't need
Alloy clutch and throttle pedals
Fit an aero screen
I haven't weighed my widetrack stuff yet, but I'll bet it weighs more than the standard track 'bones. More metal... Plus add in the SBD chassis mods (adding metal to the chassis), fitting SBD wide track probably isn't a weight saving option....
Was on my car the wish bones are lighter both outer joints are lighter and this more than made up for the rose joints on the inboard end and the track rod ends are now rose joints
How much difference?
Carn't remember I weighed them at the time and it was a bit lighter
Ball joints to rose joints save a bit on the outer end
SBD's wishbones are thiner tubing
so when every 100g's or 4 oz's is added up the overall weight is noticeable
Its like looking after the pennies and the pounds will look after themselves [blatters you should be able to relate to that or so I am told] :D  :D  :D  :D  :D
out of interest, has anybody tried to remove the top mountings for the inertia reel seatbelts? they look like they're solid, pretty heavy and not used by people with harnesses. just wondering how much they weigh and how hard they are to remove?
Not sure about weight but I have seen a couple of cars where they have been removed. I was thinking about it as I intend fitting a harness. Think WF do a trim strip which fills the gap so it must be quite common.
Mitch
Should be fairly simple if you are handy with a grinder :D
I removed mine, but had to go out and buy a new grinder half way through!
They weigh over a kg.
So on the usual rule of thumb of 100quid per kilo saved that applies to wheels, brakes etc, it was a worthwhile mod even when the new grinder is taken into consideration.
I made a jig up to ensure the chassis didnt get damaged, and the cut was straight and flat.
understatement of the year!  :D
Ive got the ones i removed in the garage so I'll post a pic.  The boss isnt only welded on the top of the chassis rail.  The bottom of the boss where it meets the chassis rail is turned down and it connects up with the underside of the chassis tube.
Ive just stuck them on the scales and they weigh 875 grams with plenty of angle grinder marks..  Probably nearer 1kg when in one piece
There not the easiest things to remove as they are connected from the bottom.  I just cut all the way round and then got the correct 4lb screw driver and bashed the living daylights from it.... they came out eventually
cheers
mark
ok, thanks guys. looks like ive a happy hour or two with a hacksaw or grinder ahead of me.
pic would be interesting.
