deller Posted August 13, 2004 Share Posted August 13, 2004 As I intend to change the rear lights after the car has passed the SVA I want mount the fog and reverse lamp from the rear chassis member under the body rather the westfield suggested position and drill holes in the body that would need filling once they were removed. Does anyone know of any reason why they would not pass SVA if mounted here? Westfield suggest that they only mount them in line with the rear lights for asthetic reasons! (although you could question why they chose those lights in the first place) thanks Paul Quote Link to comment Share on other sites More sharing options...
scott beeland Posted August 13, 2004 Share Posted August 13, 2004 Think you might have to check minimum height issues for the fog light Quote Link to comment Share on other sites More sharing options...
Blatman Posted August 13, 2004 Share Posted August 13, 2004 Are fog and reverse lights an SVA requirement? They certainly aren't for MOT's... Quote Link to comment Share on other sites More sharing options...
neilb Posted August 13, 2004 Share Posted August 13, 2004 Fog is required, reverse is not but if fitted it must work. I found that under the body was too low so mounted it on a bracket level with the bottom. HTH Neil Quote Link to comment Share on other sites More sharing options...
Nick A Posted August 13, 2004 Share Posted August 13, 2004 fog lamps are an Mot requirement but this does depend on the year of registration vehicles first used after 1st april 1980 require a fog lamp to os/centre Quote Link to comment Share on other sites More sharing options...
pistonbroke2 Posted August 13, 2004 Share Posted August 13, 2004 mount it low watch it go Quote Link to comment Share on other sites More sharing options...
Crash Override Posted August 13, 2004 Share Posted August 13, 2004 There isn't a minimum height requirment I don't think, just a maximum one...But be careful if you mount them to low like others have said you'll loose them, espeically when your car gets put on the brake test machine (which I think they'll do LSD or not as the forces put through it aren't strong enough to damage the diff, so I was told by my tester.) Quote Link to comment Share on other sites More sharing options...
deller Posted August 13, 2004 Author Share Posted August 13, 2004 Thanks for the replies, I thought I would have some problemss with ground clearance but didn't intend driving it for long with them on. Neil, good idea, did your car go through SVA mounted like this? Quote Link to comment Share on other sites More sharing options...
davidgh Posted August 13, 2004 Share Posted August 13, 2004 Sorry to be the bearer of bad news, but I think there is a minimum height for SVA. My notes say: Rear light SVA Rules -- Fog (1): On centre line or to offside. Minimum 100mm from stop lamp (unless in cluster). Minimum height = 250mm. I can't remember whether the minimum height is to underside or centre of the lamp. HTH David Quote Link to comment Share on other sites More sharing options...
deller Posted August 14, 2004 Author Share Posted August 14, 2004 Just interpreted the SVA manual - the whole illuminating surface has to be within the 250mm minimum limit i.e. the bottom of the light has to be at least 250mm clear of the ground. This should be OK if I just keep the suspension set fairly high until after SVA when it will drop substantially! thanks everyone.. Quote Link to comment Share on other sites More sharing options...
geelhoed Posted August 14, 2004 Share Posted August 14, 2004 As a temporary solution you could mount them on the spare wheel bracket (if you have one) Quote Link to comment Share on other sites More sharing options...
neilwillis Posted August 14, 2004 Share Posted August 14, 2004 I hate to worry you, but did you know you fitted the steering wheel to the passenger side? Quote Link to comment Share on other sites More sharing options...
geelhoed Posted August 15, 2004 Share Posted August 15, 2004 I hate to worry you, but did you know you fitted the steering wheel to the passenger side? Damn! Luckily it's not mine. It's DutchWestfield's one. But now that I took another look at mine it's also on the left!! Quote Link to comment Share on other sites More sharing options...
neilb Posted August 16, 2004 Share Posted August 16, 2004 Neil, good idea, did your car go through SVA mounted like this? Yes pass with the fog light like that, just make sure that the bracket and light is rounded off. When you do mount the fog light you need to make sure that it is veritcal Quote Link to comment Share on other sites More sharing options...
DutchWestfield Posted August 18, 2004 Share Posted August 18, 2004 Oi, that's my car at SVA indeed. I used a set of universal reverse and fog lights. No radius issues in this way. A strait bit of ali strip connected the lights to the number plate holder. The holes in the number plate holder dissapeared behing the licence plate. Note that my SVA tester had driven the car in the break test rollers too far to the left (in the red circle). After fidling around with the brake tester for a while he said that there was a problem with the break balance at the front. I suggested him that he would let me drive the car onto the brake test rollers... Quote Link to comment Share on other sites More sharing options...
