Ally Fuel Tank....
Okay, I'm not going to pretend it's in great knick, it's a little "used" looking, but it could be used as the basis for a modified tank for sprinting, perhaps?
It's a standard Westfield 6 gallon carb feed tank, modified for injection use with a fuel return pipe. Inlet & outlet are both push-on hose type, not JIC fittings.
Reason for change was that it started weeping fuel from one of the welds from the internal baffles...again, not pretending it's ready for use as-is, it's just that I couldn't be a**ed fixing it and happened to be near Kingswinford at the time!  :p
So, it's currently taking up room, but haven't got the heart to take it down the tip, someone may be able to make use of it.
I dunno, offers plus carriage (monetary, not farmyard, thanks very much all the same :D  )
Spen
