sir camel toe Posted July 24, 2004 Share Posted July 24, 2004 hi chaps hope you can help there is oily smoke cumin from the dip stick oil filler and oil catch tank filter from my crossflow engine have i blown a seal or somthing Quote Link to comment Share on other sites More sharing options...
the bear Posted July 24, 2004 Share Posted July 24, 2004 Dont want to be a purveyor of doom and gloom man but......... Thats how my recent problems started. Is there any smoke from the exhaust when you rev and lift off? What carbs are you running? PM me and I'll send you a phone number and I will relate the sequence of events leading up to a complete engine rebuild. It's to long a story to post here. Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 24, 2004 Author Share Posted July 24, 2004 hi mate i run twin 40s it only happened after i raced a scooby must of gave it to much right foot did beat him tho Quote Link to comment Share on other sites More sharing options...
the bear Posted July 24, 2004 Share Posted July 24, 2004 My misery could have been started by a duff Solex carb,also a twin 40 set up but unknown to me it was flooding the bore of cylinder 4. Is the engine running hotter now than before? Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 24, 2004 Author Share Posted July 24, 2004 no its the same as before . one of my mates says it might be a oil ring round the piston what do u reckon Quote Link to comment Share on other sites More sharing options...
the bear Posted July 24, 2004 Share Posted July 24, 2004 Basically thats where mine ended up, started with a washed bore then the lack of oil caused a heat build up, head gasket failure, and possibly caused the circlip to fail and get trapped between the bore and the piston damaging both. Got it back last night after a total rebuild. It will now be loads faster, race cam, lightened flywheel the whole nine yards but The cost was unreal I am no expert it could be similar to mine but it also could be normal, I was told originally that xflows do have a tendancy to breath a bit. Perhaps some of the others more experienced and wise may have some other answers. Good luck with it whatever. Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 24, 2004 Author Share Posted July 24, 2004 how much did u pay for the mods mate if u dont mind me asking. Quote Link to comment Share on other sites More sharing options...
the bear Posted July 24, 2004 Share Posted July 24, 2004 Engine was £850 plus fitting labour, replaced carbs (£250) and set up including twin cable linkage (£100) and loads of mucking about. All up about £1500. I had a load of other stuff done as well and have just forked out £2200. Still it's only money eh!!!! Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 24, 2004 Author Share Posted July 24, 2004 ill have to see whats up with mine then start modin cheers for the help mate Quote Link to comment Share on other sites More sharing options...
S8ight Posted July 24, 2004 Share Posted July 24, 2004 have i blown a seal or somthing now i could come out with a very crude joke about that, but i'll refrain Quote Link to comment Share on other sites More sharing options...
Blatman Posted July 25, 2004 Share Posted July 25, 2004 Do you have a catch tank? If so is the catch tank full? If so empty it, and see if the symptoms go away.... Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 25, 2004 Author Share Posted July 25, 2004 tried that Quote Link to comment Share on other sites More sharing options...
7SE Posted July 26, 2004 Share Posted July 26, 2004 Is your breather to the catch tank blocked? All x/flows breathe quite heavily and if the block breather is blocked or restricted it will start to breath out of the dipstick tube - being the next easiest exit. Do a seach on the forum, from the beginning - there are some useful threads about x/flow breather pipework. Breather -> Rocker -> catch tank. Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 26, 2004 Author Share Posted July 26, 2004 my mate has just had a look and said its the piston ring that has gone Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 28, 2004 Author Share Posted July 28, 2004 just had the head of the engine and one of my pistons is melted gutted the internal bore size of the liners is 0.80mm--8cm does anybody now where i can get this and pistons to match+how much they will rob me of my hard earned cash cheers daz Quote Link to comment Share on other sites More sharing options...
