healthfreak Posted July 6, 2004 Share Posted July 6, 2004 Anyone recommend a good bike engine mechanic. I'm now the proud owner of two knackered Blackbird engines thanks to a broken scavenge pump. Hopefully I'll get a bulk discount!! I'm not shy of travelling to get a good service/reasonable pricing...... Cheers Pat Quote Link to comment Share on other sites More sharing options...
Crash Override Posted July 6, 2004 Share Posted July 6, 2004 Pat you have e-mail, hope it helps. Quote Link to comment Share on other sites More sharing options...
S8ight Posted July 6, 2004 Share Posted July 6, 2004 where are you ? Quote Link to comment Share on other sites More sharing options...
Crash Override Posted July 6, 2004 Share Posted July 6, 2004 where are you ? Doesn't anyone read profiles? He's in Macclesfield. Quote Link to comment Share on other sites More sharing options...
S8ight Posted July 7, 2004 Share Posted July 7, 2004 Quote Link to comment Share on other sites More sharing options...
ChrisG Posted July 8, 2004 Share Posted July 8, 2004 The thing is if they've died from oil starvation then its quite likely that the cost to fix them will be about as much as the cost of a new engine. The cranks are rarely salvagable as they are coated, there will likely be piston / bore / con'rod damage and the gasket sets etc are expensive (£150-250), so even doing it yourself its a fair old hit. I looked at rebuilding the two blade engine's Ive gone through, but I ended up breaking them for spares and flogging some of the bits on Ebay which gets a reasonable return and softens the blow of the new engine. Chris Quote Link to comment Share on other sites More sharing options...
