markh1970 Posted July 5, 2004 Share Posted July 5, 2004 Can anyone say what the correct oil temp and pressure should be? Car is stationary after a good blat. Car is Megabusa Just for my peace of mind. Thanks Quote Link to comment Share on other sites More sharing options...
markh1970 Posted July 5, 2004 Author Share Posted July 5, 2004 Edited due to incompetence Quote Link to comment Share on other sites More sharing options...
adhawkins Posted July 5, 2004 Share Posted July 5, 2004 Reply deleted due to an incorrect engine guess Andy Quote Link to comment Share on other sites More sharing options...
sjtoolan Posted July 6, 2004 Share Posted July 6, 2004 I suppose it depends on where you are taking the measurements, what setup you have... But, my car, with the westfield dry sump, and a VDO temp sensor in the bottom of the dry sump tank, I get the following. Oil pressure approx 4 bar when the engine is started from cold. Once the engine and oil has warmed up, ie after a good blat, oil pressure will read around 1/2 bar at idle, some cars read 0 bar (but the needle has moved up a bit from it's stop). Oil temperature really depends on how good a blat. Normal driving on the roads and mine reads around 50 degC, after a really good thrash, ie on track, it'll be up to 90 or maybe 100degC. Simon. Quote Link to comment Share on other sites More sharing options...
