sir camel toe Posted July 2, 2004 Share Posted July 2, 2004 hi chaps what are the best ways off make my car lighter its a se with a 1700 cross flow plus what cams do u guys use. on 40s at mo upgrading to 45 throttle boddies soon any info would be a great help cheers daz Quote Link to comment Share on other sites More sharing options...
mb893 Posted July 2, 2004 Share Posted July 2, 2004 hi chaps what are the best ways off make my car lighter its a se with a 1700 cross flow Hmmm, tell fibs? Wheels/tyres/uprights/ali shocks/ali calipers/disks drilled to within an inch of their lives/throw things away/seats/weather gear/end can/non stressed fixings/drill many many holes in things (only joking)/boot box/boot box return (can't believe I said that one! )/erm that's it. Things to bear in mind: 13" rims and tyres weigh less (generally) than 14/15/16" ones, Any ali bits that replace steel bits just have got to be lighter, Do you use the weather gear, no? Throw it away. Wind screen/wiper/heater, oooh a whole 10kg extra... aeroscreen (TimD/the Factory) weigh in at around 1 to 2 Kg... Eat less..... common sense stuff really, you start from A and then only add/replace with lighter things and arrive at B Quote Link to comment Share on other sites More sharing options...
TrevP Posted July 2, 2004 Share Posted July 2, 2004 hi chaps what are the best ways off make my car lighter its a se with a 1700 cross flow take out the engine Quote Link to comment Share on other sites More sharing options...
mb893 Posted July 2, 2004 Share Posted July 2, 2004 take out the engine Dang, forgot that one! Quote Link to comment Share on other sites More sharing options...
TrevP Posted July 2, 2004 Share Posted July 2, 2004 i suppose you could also cut a hole in the floor this would then give you another 2 feet of torque:D Quote Link to comment Share on other sites More sharing options...
mb893 Posted July 2, 2004 Share Posted July 2, 2004 Now you're just getting technical... Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 2, 2004 Author Share Posted July 2, 2004 ill take it not many people like xflows on here Quote Link to comment Share on other sites More sharing options...
Rob Navin Posted July 2, 2004 Share Posted July 2, 2004 Envy is such a sad thing The advice given by MB893 is true. You will have to make sacrifices to comfort if you want to go truly light weight but this is the cheapest way to go. Throw out the carpets, spare wheel and keep going until you have got a striped out racer As for cams my last 135bhp engine used a kent 244 which seems to be the norm for that power level. If you have a look on the Kent website there is lots of info to guide your choice. For local advice speak to Johnny Weston-Taylor at the next Peacock night HTH Rob Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 2, 2004 Author Share Posted July 2, 2004 rob shall i not bother with th 45 tbs then +will u be up at the next peacock meeting mate Quote Link to comment Share on other sites More sharing options...
S8ight Posted July 2, 2004 Share Posted July 2, 2004 THIS makes quite good reading for lightening Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 2, 2004 Author Share Posted July 2, 2004 cheers s8ight thanks 4 the advice lads Quote Link to comment Share on other sites More sharing options...
Rob Navin Posted July 2, 2004 Share Posted July 2, 2004 Hi mate I would hold off on the expense of fitting the TB's until you have fully investigated what the advantage will be to the engine you are running at the moment and the costs involved in making the best of them. I will PM you my number and we can have a chat if that helps ? I should be at the next meet at the Peacock as long as I am not tied up at work. Rob Quote Link to comment Share on other sites More sharing options...
sir camel toe Posted July 2, 2004 Author Share Posted July 2, 2004 rob u have pm Quote Link to comment Share on other sites More sharing options...
Major Stare Posted July 3, 2004 Share Posted July 3, 2004 as long as I am not tied up at work. Rob Blinkin hell Rob........what kind of job do you have ? Quote Link to comment Share on other sites More sharing options...
timd Posted July 3, 2004 Share Posted July 3, 2004 Wind screen/wiper/heater, oooh a whole 10kg extra... aeroscreen (TimD/the Factory) weigh in at around 1 to 2 Kg... *ahem* My screens weigh just 300grams actually.. They are clearly the only sensible choice for those who are serious about weight saving! Quote Link to comment Share on other sites More sharing options...
