This is to test the water so to speak, as I'm not deffinately selling up, but who knows if the right offer comes along . . . .
This car used to run with a trusty old crossflow, and last season scored 5 out of 5 class wins, before I got a little tipsy one evening at curborogh and broke the gearbox the following day.  The gearbox is now fully rebuilt with all new parts by BGH and a new 1800 Zetec engine has been installed the spec is as follows :-
Engine
1800 zetec - 189hp
Skimmed and ported head
Balanced bottom end
Kent Super Sport Cams (need to confirm spec, but wildest possible)
Solid larger lifters
Twin 45's
DTA Engine Management
Cosworth Rod bolts
Will rev to 7,750, but max power at about 7,400 (have printout somewhere)
Cost over £5K this winter.
Drivetrain
BGH 5 speed box (all new internals about 1500miles ago)
2.54 first
0.79 fifth
Proper gearbox extention with long gearlever for fast precise changes
Alloy Bellhousing
4.4 English Diff in Westfield Housing fitted with Quaife ATB (new last season)
Brakes / Suspension
CAT Motorsport Ally 4 pot calipers at front
Tarox solid discs on front
RS2000 9" drums on rear
Brand new AVO shockers and springs
Front anti-roll bar
Quick Rak steering - 2.2 turns lock to lock
Other
2 Sets of 15inch rims with one set almost new and one set scrubbed Toyo Proxys.  One set of rims are Super Legaras, other set are only 5.5kg each, and could benefit from powder coating.
Tony Laws 4-2-1 manifold
Wunoff Alluminium Silencer
Plays-Kool GRP Race seat (Specially Widened)
Sabelt 3" 6 point drivers harness
Sabelt 3" 4 point passenger harness
Spa Tacho and with built in speedo (New, and records trip / odometer / 0-60 / 3 sequential shift lights)
External shift light run off DTA management
Polo G60 Radiator
Lightweight alternator
Momo steering wheel
Carbon effect front lights (which pass MOT's)
Carbon effect cycle wings
recently powder coated various front end bits.
Small Race battery
Ally oil catch tank
RAC Roll bar
Removable boot cover for easy access to rear
High flow fuel pump and Filer King fuel regulator
Carbon Fiber rear and side mirrors.
I think thats about it, but it must be stressed that this car is set up to be raced, although since the rebuild of the gearbox and engine, it has not been on the track, other than at Elvington earlier this year to get some miles on the engine prior to final rolling road tuning after engine swap.
The chassis is a very early wide bodied item, and the body work is British Racing Green with a yellow nose.  The bodywork is fine if this car is to be used for sprinting / hillclimbing, and it comes without carpets or weather gear.
The car weights in at about 520kg and the spec speaks for itself.  The car is capable of 0-60 in 4.2 secs, as tested with the SPA tacho / speedo, and would make an ideal sprint car capable of challenging for the road going under 1800 class.
Oh, and a Carbon Fibre timing strut.
Genuine sensible offers only, as I'm not going to let it go unless I get a usefull figure.
What you gonna get Mike? A Blade? A Busa ? or a bigger Lens? :bangshead:
