Pete.H Posted May 17, 2004 Share Posted May 17, 2004 Has anyone else found on a zetec engine, exhaust downpipe No3 on the manafold hits the crankcase vent on the side of the block.Tried vent from an Escort and now a Mondeo, but with no luck. Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted May 17, 2004 Share Posted May 17, 2004 Dunnel blanks this off I have replaced this with my own plate and breather pipe and piped it into the cam cover You could pip it to a catch tank [i have had it this way before its ok] Quote Link to comment Share on other sites More sharing options...
CedricTheBrave Posted May 17, 2004 Share Posted May 17, 2004 I fitted a 1.8 one to my 2.0 its much smaller seems to work ok Quote Link to comment Share on other sites More sharing options...
Pete.H Posted May 18, 2004 Author Share Posted May 18, 2004 Never simple is it ! Both the vents I have are from very early engines maybe Ford changed them later on? Should have mentioned it's a standard Westfield manafold and exhaust. Quote Link to comment Share on other sites More sharing options...
Kevin Wood Posted May 19, 2004 Share Posted May 19, 2004 I have seen 2 sizes of vents so maybe you've been unlucky and got the larger one. I would have thought blanking the breather would be OK as long as the cam cover breather is open. A rummage at a scrap yard might yield a breather that fits though. Kevin Quote Link to comment Share on other sites More sharing options...
thos Posted May 19, 2004 Share Posted May 19, 2004 What kind of manifold have you got ? There's a thread around here somewhere that suggests keeping the breather and not blanking it off. Quote Link to comment Share on other sites More sharing options...
Pete.H Posted May 22, 2004 Author Share Posted May 22, 2004 Problem solved ! Ford changed its design half way through the Zetecs life.Part required is finis No 1113157. Quote Link to comment Share on other sites More sharing options...
