seat fitment into seiw Tillet any help
hello im after some general help please i would like to remove my current seats and replace with Tillet b6 seats any one know what's needed to fit them and how hard it is to do not sure what runners needed make them fit
Speak to David at @Tillett Car Seats, he’ll help answer any questions you have.
Thanks i have sent a message
I have a (single) B6 and mounts that I’ll be selling if you are interested?
Yea ide be interested send me a message with a photo and price please
I've fitted B6 seats to mine, bought through this forum from David.
The Tillet runners work just fine, although you'll certainly need to drill new holes. And you need the seat option with the rolled edge cut off for them to fit.
Other than that, only thing to watch for when fitting is clearance for the shoulder of the seat when pushed back. It's a bit of a tight fit, but not too much so.
Thanks for tagging.
The B6 seats have M8 thread inserts in the base and bolt from underneath.
Most cars have the drivers side on runners and passenger seat fixed.  Without runners spacers are needed or the bowl of the seat will touch the floor first.  We can supply these.
Its easy to fix in later cars with the solid floor.
Cars with the alloy floor and steel cross members are a little trickier as the spacing is not quite right for most seats.  Even the factory tended to tack weld an M8 bolt to the rear end of the runner so that it would span the spacing.
Please message me if any further questions.
Regards
David
B6-Dimensions.pdf
