ChrisG Posted April 28, 2004 Posted April 28, 2004 Ive not seen any in the flesh but I assume the polybush goes all the way through the damper hole and has a central metal sleeve through the middle of that. I think if you took all that lot out you'd end up with a hole needing a 1" diameter bolt if you didnt put a rosejoint or something inside. Chris Quote
Blatman Posted April 28, 2004 Posted April 28, 2004 That's what I'm not sure about, and was rather hoping that that isn't the case. I've spent enough on rose joints and spherical bearings recently. I'm just in denial...... I'm sure you're right though, which I guess means I'll be reaching for Mr Visa again....... Quote
ChrisG Posted April 29, 2004 Posted April 29, 2004 Have a gander at Catflap's pic of his damper with the speherical bearing. It looks like it would be a fairly substantial hole if the bearing wasnt there, so Id say you're right about Mr Visa Quote
Blatman Posted April 29, 2004 Posted April 29, 2004 Yeah, I had a look, and it seems you're right...... oh well....... Quote
