Donington Park - 2nd July
I’ve just booked Donington using our Javelin discount code for the evening on 2nd July.
Anyone else going?
  • Naranja_Al changed the title to Donington Park - 2nd July
Anyone else going?
Yep!! 😀
I better get some proper tyres ready to keep up with you!
Are you doing the day or evening @Mole?
The day
  • 2 months later...
I thought I’d posted this after our track day at Donington on 2nd July. My car ran faultlessly and was great fun throughout the afternoon and evening sessions.
Sadly, @Mole’s  day was cut short by a cracked chassis, which meant we couldn’t all get out on track together.
My friend didn’t have the best of luck either — while I was following him down the Wheatcroft Straight, his car decided to empty all of its engine oil onto the circuit!
Second-hand engine sourced and now back in the car. Good job they are nice and cheap!
The old setup was running 1 bar of boost on a standard bottom end, with the exception of MaXpeeding rods. The new engine is completely standard — my mate reckons that should still be fine for 1 bar of boost?
I’m not so sure after looking at the photos above! 🤦‍♂️
Question for those more knowledgeable (I’m keen to learn):
1) Detonation / pre-ignition?
2) Piston ring gaps too tight?
3) IATs too high?
4) Something else?
  • Sad 2
I'm no expert but personally I would not risk that. Mine is a 2.0 blacktop Zetec but running the same boost. I have armoured con rods, ARP rod bolts, forged pistons, heavy duty big end and main bearings and heavy duty valve springs. Also ARP flywheel bolts. Different engine I know, but I'd still be cautious.
I am glad he is up and running Al... that is definitely a mess and would explain the oil everywhere..
I wouldn't know what went first however the damage on the piston looks more like fragment damage rather than detonation?
Hopefully I will be back on track end of September..it has been me taking time to mend rather than the car!
