colnagowetdream Posted April 18, 2004 Share Posted April 18, 2004 I have just fitted my Vx 2.0l redtop into my old SE and a couple poblems have arisen, and with the wealth of knowledge out there I wondered if you could cast some ideas my way! 1. The bell mouths on throttle bodies trumpets rub on the chassis rail. Do I fit longer trumpets (what effect will this have on performance) and then fit foam filters or do I mill an angleon the intake manifold to give the the throttle bodies a upward tilt and therefore clear the chassis rail (there seems to be just enough meat on the manifold). I cannot raise the engine as it is a tight fit to get it under the original bonnet 2. My chassis is a 4 speed (apparently) and was converted to 5 speed by the previous owner. The gear lever of my type 9 is above the chassis rails so I cannot get the transmission tunnel flat plate on (this was also a problem with the car when it had the X-flow in). Do Ford do more than 1 gearbox mount, there doesn't seem to much in the mount that I have that can be reduced. 3. Where can I find out how the flowpath of coolant for the Vx engine is supposed to go as all I have is a load of hoses and pipes and don't have a clue where they all go!! Quote Link to comment Share on other sites More sharing options...
oioi Posted April 18, 2004 Share Posted April 18, 2004 3. see Quote Link to comment Share on other sites More sharing options...
pete g Posted April 18, 2004 Share Posted April 18, 2004 can you lower the exhaust side engine mount a little more this would angle the inlet side up a bit. would not need much Quote Link to comment Share on other sites More sharing options...
