legineyt Posted April 17, 2004 Share Posted April 17, 2004 Can anyone recommend the best make/type of tyre for fast road use and occasional track days. I require max.dry grip but obviously must also have reasonable grip in damp conditions. Size as fitted 185/60/14. Quote Link to comment Share on other sites More sharing options...
Eccentric_Rich Posted April 17, 2004 Share Posted April 17, 2004 You'll find 'War and Peace' written on this subject if you do a search but in answer to your question I would suggest Yokohama AO32R's as a good all round tyre in terms of price and longevity for road and track use. Richard. Quote Link to comment Share on other sites More sharing options...
legineyt Posted April 17, 2004 Author Share Posted April 17, 2004 Thanks Richard, I will price some up, Nigel. Quote Link to comment Share on other sites More sharing options...
higgsti Posted April 17, 2004 Share Posted April 17, 2004 yoko 048s better than o32s if you venture out in all weathers like me Quote Link to comment Share on other sites More sharing options...
DickieB Posted April 18, 2004 Share Posted April 18, 2004 32s and 48s are great as long as you only want them to last for a few thousand miles. If you want to do more mileage, then you will have to get a tyre that resembles a car tyre and not a motorbike tyre. In which case, you should go for the Yoko 539 - about £200 per set of 4. Dickie Quote Link to comment Share on other sites More sharing options...
YouMustBeJoking Posted April 18, 2004 Share Posted April 18, 2004 I recently replaced my tyres. I felt that "sticky" tyres such as AO32 and 48 etc would generate too much grip and encouage me to drive too fast on the road. The sump has been shortened but I have no idea about the effectiveness of any baffles that may or may not be fitted, leading to worries about lack of lubrication causing engine failure. I therefore followed Dickie's advice and bought Yoko A539. £199 for four, fitted, balanced, new valve and including VAT from local tyre dealer (185/60 X 13) Quote Link to comment Share on other sites More sharing options...
oioi Posted April 19, 2004 Share Posted April 19, 2004 one thing to note, once you go for A048s (or 32's) you will never ever go back. they are awesome one tyre not yet mentioned (for completeness) A021r, better than a road tyre, longer (read twice as many miles) life expectancy than the dry tyre of the A048 Mike Quote Link to comment Share on other sites More sharing options...
worldwidewebs Posted April 19, 2004 Share Posted April 19, 2004 Don't mess about - get yourself a set of Avon ACB10s. Isn't that right Ash? Andy Quote Link to comment Share on other sites More sharing options...
Eccentric_Rich Posted April 19, 2004 Share Posted April 19, 2004 ACB10's are a great track day tyre but a bit expensive for everyday road use. They're not available in the 14 inch diameter Legin (first post above)requires either. Richard. Quote Link to comment Share on other sites More sharing options...
worldwidewebs Posted April 19, 2004 Share Posted April 19, 2004 Point taken Richard, but it may be better to get a separate set of wheels/tyres for track days. I have "standard" tyres for road and wet track and a set of ACB10s for dry track which I carry to the circuit on a frame made by Westfieldman2000 (thanks Paul). The original post did state a requirement for "max dry grip", which always means a compromise somewhere so perhps the compromise is a separate set of wheels! Just my 2p worth of course Cheers Andy Quote Link to comment Share on other sites More sharing options...
felters Posted April 19, 2004 Share Posted April 19, 2004 Isn't the castor angle different for ACB10 vs. a normal radial tyre? Btw I use A021's... Quote Link to comment Share on other sites More sharing options...
Blatman Posted April 19, 2004 Share Posted April 19, 2004 Nope, camber.......... Quote Link to comment Share on other sites More sharing options...
