My home-built project that needs an owner who will actually use it. Time to accept I gave no thought what I'd do with it once I'd built it.....  A common refrain from me, "we have 3 cars but barely need 1". In 2023 the Midlana went to the MOT & back and that was it. Last year Vickie 'encouraged' me to use the car more so we did get out in it once or twice, which I enjoyed, but the truth is I just have no use for it as I am practically a recluse these days. So, as the saying goes, 'genuine reason for sale'. It's not a 'good' reason, but it is true.
£12,500
If the asking price is achieved, sale will include a bunch of spares etc as follows.
Engine gaskets, spare set of used ignition coils, spare throttle pedal pot, spare MAF, spare suspension parts, spare diff (used but good), camlocks for the V6, plus any other pertinent bits (spare wiper motor, spare dash clusters etc). Will include all the templates I used for making the body panels, screen template, assorted 3D printed parts files to recreate them if required. Car currently has inertia belts but will include harnesses as shown in the shot below. Spare master cylinders.
If the asking price is not achieved, none of the above listed parts will be included but can be purchased separately. Last time I sold a kit I practically gave it away, along with lots of valuable parts. Won't be doing that again.
(Added for clarity, no spares will be offered for sale unless the car sells below asking price. If that happens, any left over will be advertised separately.)
Can be viewed any time by arrangement.
A few pictures so you have an idea what it is:
Very briefly:
Car has MX5 NA front & rear uprights, front suspension is double wishbone with inboard vertical dampers with rockers & pushrods, rear is lower semi-trailing arm and upper wishbone. All suspension joints are 1/2" rod ends or larger, or spherical bearings in cups. Pro-tech 1.9" dampers. Steering rack is MX5 (currently a de-powered PAS rack, was originally a manual rack but I found this a bit 'slow'). Front brakes are Wilwood Midilite with Focus ST 300mm vented discs, rears are Hyundai i30N calipers with BMW JCW Mini vented 316mm discs. Wilwood pedalbox and master cylinders.
Engine is a stock Alfa Busso 3.0 V6 taken from a 1999 Alfa 166 so makes around 220bhp/200lbft. Gearbox is a 6 speed from a 156 V6 for the shorter diff ratio. ECU is stock from the donor 166 so includes working cruise control and passes a CAT test with ease (although it doesn't need one at MOT being a Q plate).
Instruments are modified Alfa 166. Loom is mostly derived from the donor car and retains all the original switchgear and functions, including the Alfa CODE engine immobiliser system integrated into the ECU. Dash has a home-brew fuel gauge calibrator to match it to the Exige fuel tank & sender, which makes it accurate.
JK Composites seats.
Since first building it and getting the IVA in March 2021, I've fitted LED headlights, put a Sparco steering wheel on it with a QR, swapped out the harnesses for inertia reels and made some suspension mods at the back to add some extra droop travel. Last year while I had the engine out to do the suspension mods, I also fixed an oil leak that had developed, so it had a new cambelt and yet another water pump while it was in bits as well as a complete new set of all oil seals.
Located near Evesham, Worcestershire. chris.savage.01@btinternet.com
For more detail than any sane person could want to know, please see the following threads:
and:
https://www.stratosec.com/Forum/showthread.php/3073-Non-Stratos-build-project?highlight=non-stratos
and finally:
https://www.midlana.com/forum/viewtopic.php?f=5&t=651
which was where the idea came from originally.   (last two sites may require you to register??)
  • Like 7
  • Sad 2
Beautiful car, with the added bonus of the Alfa V6 engine... Bet it sings very well 😍
It actually sounds fonkin awesome when hoofing it :)
  • Haha 1
I’ve seen the beast in person and a read through the build thread will show the level of attention and detail that went into building it.  Anyone even a tiny bit interested will not be disappointed when they see it in person.  Delightful car.  GLWTS!
@corsechris didn't see this coming!  As the good Captain says, this is an amazing car that has been built with total attention to detail.  At that price I'd buy it myself if I was a bit younger.  GLWTS
What a stunning car! I’ve seen you mention the Midlana multiple times but had no idea what it was 🤪. Looks a really well thought out design and must be a hoot to drive. Shame you are having sell it, but hopefully someone will get to enjoy it soon. Good luck with the sale.
PS if you promise not to tell anyone, not being familiar with the car it took me more than a few seconds to work out where the engine was 🤣🤣. I guess the clue is in the name!
  • Haha 1
That must be soo cool car! I have two Alfas 156 2,5  and 166 3,2 with Busso V6 engines (well three ALfas - 3rd is 156 factory track - cup car with 2.0Twinspark slightly modified) . Was always thinking "how to put Busso into 7type car..." (I know its differretn, but You know the lightness of kitcar, resposibility from steering, brakes, acceleration,  no electronics and THIS engine with its exceptional character, resposibility, sound, it never sounds the same, on cold day, on hot day, ets, "its alive" :) , its really not just engine. Who had a chance to ride one will know. Only those FWD platforms I have it mounted to...  not really are great for that engine. But in soo small lightweight car as Midlana - it must be really something!
Wish It  was announced 2-3 years ago, now too many kitrcars for me and no place, and those export troubles.. But someone is going to have LOOOT of fun with such legendary engine and looking at it - perfectly build and well thought out in detail car build with for sure lot of effort aroud that engine.
  • 3 months later...
Bump.
Just got a new MOT today and I fitted a dash cam/rear view mirror/reversing camera with GPS thingy the other week. And filled the petrol tank on the way back from the MOT......
Did 198 miles in it last year.
  • 1 month later...
By way of an entirely obvious and un-subtle bump...the car was in Complete Car Builder magazine this issue and will be in Total Kit Car next (or possibly next plus one) issue.
  • 3 months later...
And another blatant bump. Not sure how many I get before I get a red card....
  • Like 4
I'm very surprised this hasn't gone. I remember following the build thread with interest, and onyone who has done so knows that this is a reqlly well thought out and well put together car.
I suspect the fact it is a one-off will always make for a tough sell. It needs the right person to consider taking something like this on.
Appreciate the comments though :)
  • 2 months later...
Bump.
New Year, new price.
£12,500
