Calendar entries
I've been trying to create events in the local area calendar, but only the track day calendar seems to be available, all others are greyed out and not selectable! I've tried a laptop, edge browser and Samsung android 14 phone, no difference. Any ideas?
Not sure of the problem but just checked and all are OK for me 🤔
Must be just me then!
I'm sure this happened before, then was ok again 😖
Have you used the dropdown menu and selected All Calendars?
Yes Scott, but no difference!
I've just added the Warks meeting to the track day calendar as a test!
Not sure if it can be moved to the local area events calendar?
Same here, all seems to be working well
Has anyone found a way of importing an Excel list of Calendar events in. I've got 32 Speed Series Events to put in for 2025 ;)
I’ve sorted it out for you. 👍
I have the same issue. I can only create events in the track day calendar. If I select local events calendar, I can look but can't add
I'm glad it's not just me then!
It’s all about Permissions (as is most settings backstage and a right PITA it is, too).
The list is divided into User Group down the left and abilities across the top:
Im guessing here that when that calendar was set up, it was meant as a tool for AOs.  There might be a case for letting mere mortals like me add things to the Local Events calendar if they so desire.
@Martyn Vann - Warwickshire AO Figured it out - your account was in the wrong User Group.  You were in UK Member with Mag instead of Area Organiser and no, I don’t know why, but I fixed it.  You should now have full access to the calendar again.
It has worked!
Thank you @Captain Colonial
Once again you have used your superpowers to improve the lives of us mere mortals!!!
See my signature below 🤣
  • Haha 1
